I removed my radiator core to clean out. Where can I find the gaskets and sealer? It appears that the sealer was applied between gasket and radiator only. The core appears to have an aluminum base.
If you can not get them from Cat try a local radiator shop that does heavy truck and equipment radiator repair. I got my seal from a local shop. It looks like butal tape.
Terry
