Problem rebuilding Cat 10 Ensign Carbs
Showing 1 to 10 of 11 results
Dunefanatic
Send a private message to Dunefanatic
I was in the shop yesterday attempting to rebuild a pair of Cat 10 Ensign Carbs. I have a consistent problem with both that is puzzling me. The first carb came off a poorly running Ten but was not exhibiting the problem noted below and second was the rebuilding of a carb for an advanced swap. Both carbs seem to be getting too much gas and are leaking it out the butterfly and breathers on the bottom of the carbs. I am fairly certain it is not the float because when I remove the float and top of the carb the bowl is dry and gas has drained out. I have a gasket on the bottom and top of the venturi tube which I am fairly certain is making contain (but would not stake my life on it). Looking for advise from the BB members who may have encountered such a problem and how they resolved it.
Greg
Mon, Jan 7, 2008 2:05 AM
chugwater crawlers
Well, here is is my experience. The ensign carb on my PV-15 does the same thing. I'm told the float is sticking. I get gas running out the bottm of the carb and it makes a mess.. I tap the side of the carb and is usually frees it up and it starts.
The carb has been completley rebuilt and it still does it. I'm on my second flloat which has helped the situation.
I have another tractor with the same type carb and I never have any trouble with it.
Mon, Jan 7, 2008 2:54 AM
Pat in WI
Reply to chugwater crawlers:
Dunefanatic,
Your float can be just fine...but if the needle and seat are bad, it will always leak fuel out the bottom of the carburetor. Mine does, but not real bad. I could not find a needle and seat to match mine (non standard) so I had to try and hone the surfaces to true them up. I was close but not exact. I have just gotten use to cutting off the fuel and letting the engine burn off what is in the carburetor to shut down.
If those gaskets are not EXACT (top and bottom of venturi tube) fuel will leak by the bottom one too. But usually if fuel leaks by...the tractor will not start either. It needs to make a good seal for any air or fuel to atomize in that chamber. You know you have it right when you assemble the top and bottom halves of the carburetor, the top cover should have a tiny gap between it and the bowl gasket. When you put the screws in and tighten them up, it will pull everything tight! Over time those gaskets can dry out and shrink.
Pat in WI
Mon, Jan 7, 2008 5:49 PM
Dunefanatic
Reply to Pat in WI:
Dunefanatic,
Pat,
I definately hear what you are saying about bowl lid and a gap which is exactly what I had so I knew I had compression on the venturi gaskets. The couple things that bother me are needle not shutting off so I will attempt a bit of buffing of the needle face to clean up but it is a rubber face.
What I am still perplexed by is when I remove the bowl lid there is no fuel at all in the bowl and there is a cast ring (moate) around the venturi tube that should retain some fuel. This is the thing that perplexes me, a bowl that is wet but with no standing fuel becasue it has all drained out. I am tempted to place a extremely small bead of RTV on the bottom gasket where the venturi seats to see if this slows or stops the lareg fuel leak.
I have many other Tens with Ensign carbs that do not leak so I know I am just doing something wrong and it's annoying as hell!
Greg
Tue, Jan 8, 2008 12:19 AM
WyoCat
Greg,
If you figure it out, let me know as I have a High Ten doing the exact same thing.
Chad Enyeart
Tue, Jan 8, 2008 1:01 AM
Steve A
Reply to WyoCat:
Greg,
Greg
I am watching this thread closley for future referance, I have found a product called seal all that comes in a yellow tube with red trim, its cheap and will stand up to gas, I think better than rtv in a gas application, usually available in autoparts and hardwares. Looks and acts like clear contact cement.
Tue, Jan 8, 2008 8:56 AM
Reply to Steve A:
Greg
Is this the stuff that claims to work on leaky fuel tanks? I haven't used it in a long time but I remember it being impervious to gasoline.
Tue, Jan 8, 2008 7:02 PM
Jim Sixty
Send a private message to Jim Sixty
Reply to drujinin:
My Ten has the opposite problem. It runs fine under load and at higher rpms, but I have to leave the choke on 3/4 or so to keep it from surging at an idle. Any suggestions before I take it apart. The idle mixture screw doesn't seem to have much of an effect.
Thanks, Jim
Tue, Jan 8, 2008 8:36 PM
WyoCat
Reply to Jim Sixty:
Thanks, Jim
Jim,
These carbs were not exactly top notch for their day. The screws on my carbs do not do a whole lot either. I sure have seen a lot of 10's and PV 15's with some other make of carb modified to work on them.
Chad Enyeart
Tue, Jan 8, 2008 9:20 PM
Pat in WI
Reply to WyoCat:
Jim,
Greg,
It sounds like fuel is leaking past the lower gasket or maybe through a crack??
Try a sealing agent that is impervious to fuel as noted in these posts. If that doesn't work, there must be a crack some where in that venturi tube or near the base of it, in the bowl itself.
Mine holds fuel...it just can not completely stop it from entering the bowl past the needle and seat.
Jim D4&6,
The idle screw is nearly useless, but I do have mine turned in almost all the way. It might be backed out .75 to 1 turn at the most. This should make it extremely rich...but it runs just fine. The idle mixture screw is an air bleed so it works the opposite as the main mixture screw. Mine use to hunt at idle but when I found my magneto coupling had a lot of play in it, I fixed it, reset the timing and the hunting went away. I suspect at idle the timing was getting so late that the engine had a hard time trying to maintain a constant rpm.
Pat in WI
Thu, Jan 10, 2008 4:50 PM
Dunefanatic
Well thanks to all for their thoughts and ideas. I also call JimZ to get his opinions and through everything I was able today to get the carb working w/o leaking.
First I adjusted the T-handle bowl drain all the way in since I had not done that prior thinking it was an adjustment screw on my last rebuild attempt. I made and placed a cork gasket under the venturi tube instead of the hard paper I had that came with the carb kit. I also adjusted the high-speed plunger so there was some free-play (essentially would flood the tractor if I left this way before trying to start). I also played with the rubber on the float plunger to make sure it was floating around to seal and still soft. Last, I played around with the float to insure that not much fuel went into the bowl cavity essentially bending the brass arm.
Last to check out my work I placed a 3/8 clear PVC tube into the fuel fill when all was back together and started feeding water into the tube to see how much if any leakage I had. Tightened the bowl screws a bit more and waited 30 minutes and no leaks! 😮 Placed the carb on the tractor after draining the water out and the carb ran better than before the rebuild....what a concept. Now four more to rebuild on some smaller tractors that are not running right. 😮
Sun, Jan 13, 2008 11:22 AM
| Hartley - South Australia
