engine stand ideas need
Showing 1 to 10 of 15 results
mog5858
what dose every body use for a engine stands. i have 2 d311 and a d315 that are going to need to see some out of frame shop time. they are too heavy to just support them from the flywheel side of things right? i was thinking about making a cat sized engine stand like a car sized one and just use a worm gear to drive to rotate the motor. would a guy just be best to build a rebuild /test stand ?
Thu, Jan 21, 2016 1:21 AM
rmyram
Mog,
when i was at the dealer we had OTC stands that were designed like you are suggesting, the main difference was that we didn't hang them from the flywheel housing, they were attached to the side of the block. With your skills you could whip one up in no time, find your local Cat or JD equipment dealer and ask them if you can look at their stands to use a design reference.
here is a link to the one we had
http://www.otctools.com/products/6000-lb-revolver-diesel-engine-stand
For some reason the link won't transfer into the post, copy the above link and paste into your browser address bar and it should open up.
Thu, Jan 21, 2016 2:37 AM
Reply to rmyram:
Mog,
I clicked on the link and it opened just fine.
Much easier to build a four legged stand, castors or not unless you insist on the rotation feature.
Thu, Jan 21, 2016 7:22 AM
truckun95
Send a private message to truckun95
Another stand out there that is pretty popular is from www.twisterenginestands.com. Worth a check, lots of construction and ag dealers use OTC and twister stands.
Otherwise as stated above some stands works out great.
I built years ago a splitter stand with lots of major and minor adjustments, flat feet, and casters can overhaul engines in frame or out of frame for many ag tractors. Have split and overhauled engines in frame from a Farmall H to 8670 4wd tractor. Surely suits my situation and saved thousands of dollars in the process.
Thu, Jan 21, 2016 8:04 AM
doylex
Send a private message to doylex
I have done a few out of frames with taking the crank out. I made a C shape rear bottom frame with 2 uprights to go on the bellhousing or whatever. Mt front mount was the width of the C so different length engines could use the same back C base. Just held in place with a couple clamps or tacks. Working on the bottom side or installing piston assemblies if the block is out I prefer to lay it on some blocking sideways and work it from that angle. Pistons/rods/mains are much easier to install and torque up in a chair or on your feet instead of on your back. Cranks i set the block on top of and use a couple ratchet straps through the cylinders to pull the crank up. But hey to each his own...
Thu, Jan 21, 2016 8:07 AM
sdmuleman
Send a private message to sdmuleman
Reply to doylex:
I don't have any real experience with either engine but my guess is that with the head removed you'd probably be fine on a standard engine stand. I would probably set it on the ground upright on the oil pan and/or a stand and pull the flywheel, head, accessories, etc, then put the short block on a regular stand for disassembly. I'd guess once it's stripped to that point it's 5-600 lb, which is within the rated capacity for most common stands I've seen. Probably want to be careful if you're hammering or torquing on it too hard, but shouldn't be hard to put blocks or something under it for added support if you need it on a specific operation. Do the opposite for reassembly, build the short block on the stand then set it down on the ground for the rest. Also makes it easier to get to the top of the engine.
I have also just tipped the engine up on the flywheel end so it's vertical and done work on the short block that way. Takes a bit of care with the crank and cam, but isn't that hard.
For a longer/larger engine I would consider taking 2 engine regular engine stands and putting one on the front and one on the rear of the block - would have to modify them so the pivot is horizontal instead of the common tilt back, and would need to make sure both were aligned when you bolted them up, but this would be an easy way to get support and be able to rotate the block, though you could have issues getting to the front of the block and r&r of the cam depending on how the stand is setup. Would also have to be careful that it doesn't tip.
For me just doing a couple of engines wouldn't really be worth building a custom stand, easier to work around it.
Depends too on the person doing the work - I'm a younger guy, so working at odd angles and muscling around stuff it's that much of a problem, for someone who's older, has health issues, etc it might be much more worthwhile to have a good gear drive stand.
Thu, Jan 21, 2016 9:13 AM
Sasquatch
Reply to sdmuleman:
Here's a link to the engine stand I use at work, it's standard equipment in Ford dealerships for working on their light-to-medium duty automotive diesels that range from 900 - 1,200 lbs. It's lacking the rated capacity to even handle a fully assembled D311, but if I were to ever build a bigger one for the old Cat engines, a layout similar to this would be my choice. I love having the two attachment points, there are custom adapters that bolt to the motor mount bosses for transverse mounting as well as the universal flat plates to mount the engines in line with the stand frame. With two attachment points it is a solid setup. Like has already been mentioned, up to this point I too just get by on the old heavy Cats by utilizing simple, fixed steel stands and doing a lot of the work with the engine is one position only, flipping it upside down mainly to do just the crank work. But wow would it ever be nice to rotate them around any time you wanted, with ease.
http://www.norcoindustries.com/products/model/78200A.html
Thu, Jan 21, 2016 9:38 AM
truckun95
Reply to sdmuleman:
My honest opinion is do not under estimate the weight of an engine. Thankfully I have never personally watched and engine hit the floor but it can surely happen in a blink of an eye. First decide what you plan on using the stand for, know what you are going to be mounting to it now and in the future. Know your weight and capacitys. With those thoughts figure out what you will need to do the job without loss.
As a hobby I work on a pulling tractor, every fall or worst case with major issues we use a stand similar to the twister stand. We pull the 2,000 lb plus engine mount on stand fully outfitted from the frame. Includes turbo, exhaust, intake, fuel pump, intercooler pumps, external oil pumps, filters, brackets you name it, it's nothing to pull it out put on stand and slide the engine into the dyno. We assemble after every rebuild the same and drop the engine in.
I recommend looking into some stands, if you choose to build one make sure you consider having a professional welder weld it.
Thu, Jan 21, 2016 9:50 AM
STEPHEN
Too heavy? The flywheel housing has lots of bolt locations, you could make plate adapters for an engine stand with a gear box for turning. Although it would be impossible to hang a crankshaft or fly wheel that way.
Thu, Jan 21, 2016 10:21 AM
rmyram
i have personally watched the 6 cylinder gas engine from a 1959 international school bus hit the floor as the mechanic was trying to rotate it on the common engine stands that are designed for small block v-8's and that are found in most home shops. it also landed on the guys leg and cause some damage as well, severe bruising, some deep cuts, very lucky his leg wasn't broken.
when i was at the dealer we had some "homemade" engine stands that we also used. they did not have a rotator, but you could rotate the engine to four different positions by hand. it was a square frame with castors that had two vertical poles, on on each side. the poles had a piece of pipe welded perpendicular across the top that served as the roatation joint, and a 5/8 pin served as the holder to keep the engine in the desired position, Actually, as i think back on it, i'm pretty sure they used the round piece of metal that you weld to the tounge of a trailer hitch to rotate your swivel jack on as the rotation joint on each side of the stand. Then we had pipes that fit inside that with a plates and littel arms that you could adjust to bolt the engine to.
the engine was held by both sides of the block and the system worked falry well for the overhaul of the engine, but severly limited the ability to install the injection pump or perform a test run of the engine whilst on the stand.
the OTC rotator stand was expensive, but we could perform a test run of the engine withou having to reposition the engine from the stand to a bench or other apparatus.
many engines have ben rebuilt by laying them on their side and blocking apropriately, or standing on the flywheel housing and blocking appropriately. Use what you have at hand, respect the weight of the engine and ensure that it doens't have the ability to fall and land on you or any of your helpers. Safety should be our priority.
Thu, Jan 21, 2016 10:36 PM
mog5858
Reply to rmyram:
well guys thanks for all the info got some thinking to do. i Like otc stand you said you could do a test run on it? just looking ahead as i am a young guy now (30) and sure if i build something nice it will pay for it self in the long run. plus you do a better job if your comfortable when work plus it this is a hobby so it got to be fun. as of right now my shop is a little to small to fit any thing more than a motor or a d2 in too and i like to warm when i working. i got the welding thing covered that what i do for a living. thanks for your help boys
Fri, Jan 22, 2016 1:24 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
