is this a elevating scraper
mrsmackpaul
over in Mack Truck land this photo was shared today my question is that a elevating scraper on the back or should I say getting towed behind the float ???
Paul
[img]http://i1370.photobucket.com/albums/ag265/MrsMackPaul/Cat%20Elevating%20scraper_zps1kpx8zde.jpg[/img]
Mon, Jan 18, 2016 12:50 PM
Thank you received: 41
Hi, MrsMP.
It ackshully looks to me like a cross between an elevating grader and a Holland loader style of machine.
[attachment=33193]Cat No 48 elevating grader drawn by RD6 crawler_1A_HCHS.JPG[/attachment][attachment=33194]Cat No 48 elevating grader drawn by RD6 crawler_1_HCHS.JPG[/attachment][attachment=33195]Holland Loader, Cat D8R's, Cat777 B-dump_1A_MT.jpg[/attachment][attachment=33196]Holland Loader, Cat D8R's, Cat777 B-dump_1_MT.jpg[/attachment]
The first 2 are of a Cat Elevating Grader, a number 48, I think, and the last pair are of a Holland loader.
Hope this helps.
Mon, Jan 18, 2016 2:00 PM
Kelly
Hi, MrsMP.
Hope this helps.
mrsmackpaul, Deas Plant.
Boys that a Euclid BV Belt loader. Looks like one of the smaller ones, they made four (4) different sizes, back in the day.
They have removed the tracks and installed a set of wheels for moving.
Looks, like they are lifting the power lines over the conveyor.
Kelly
Tue, Jan 19, 2016 4:31 AM
mrsmackpaul
Reply to Kelly:
Kelly
sounds good to me the caption on the photo said Mack Euclid so what was this gem used for ????
Paul
Tue, Jan 19, 2016 6:55 AM
Reply to mrsmackpaul:
Paul
Hi, MrsMP.
They were normally used for loading trucks or other haulage units via the belt elevator that you can see sticking up at the rear, the same one which appears to giving them some static getting under power lines. The machine would take a cut out of a bank on the left side front, feed it the elevator and then into whatever haulage unit happened to be under the belt.
The various elevating graders worked in a similar fashion but on a smaller scale.
THIS is an elevating scraper - Cat parts but I don't think it was built by Cat - somebody wanted something bigger: https://www.youtube.com/watch?v=6Bmt1ux_h0M
Hi, Kelly. Thanks for the ID, M8. I sorta thought it was a belt loader but could not figure out which one. That looks like an 'Alices' Pyjamas' crawler on the float, maybe an HD16.
Tue, Jan 19, 2016 7:32 AM
