Hi 7upuller, the D6C 74A/76A belly pans are; front 9M3432, middle 9M3433, rear 9M3434. These pans use 20 of a S-1626 bolt. If you have a swinging drawbar you will also need a 9M3435 guard assem. Old Magnet will have to confirm the interchange with the D6C 99J/10K, but I think it's a good possibility. :cool2:
That's a no go. 74/76A is a three piece pan, 99J/10K is two piece with different bolt count.
The 74/76A is unique to itself.
OldMagnet,
Thank You for confirming. I'll have to look some more.
Glen
PS
Sorry about picking on you in the other thread... Hahaha
Found a 3 piece set for mine a few years ago at Quinn used parts. Might also try Fresno Tractor Inc. ((559) 233-2174). They happened to have the used SALT undercarriage for my 74A. Prices might be better.
Casey
