History of The D8 tractor
Showing 1 to 6 of 6 results
7upuller
Hey Gang,
Can someone tell me what tractor series a D8-B and D8-C models where? I am familiar with D8-D models starting with the 15-a and the D8-E model with the 14-a, but what about the "B" and "C" series?
Glen
Mon, Nov 30, 2015 6:12 AM
Thank you received: 22
Where are you getting those letters from?
I don't show any B,C, for D8's
They did use D7C for the 17A to 11878
Then D7D for the 17A11879-up (w/turbo)
D8 13A is a Direct drive w/D13000 (continuation of the 2U)
D8E 14A is a Direct Drive
D8F 14A is a Direct Drive with added oil cooled brakes & steering clutches. s/n 14A3861-up
D8D 15A is a Torque Converter Drive to s/n 15A1672
D8G 15A is a Torque Converter Drive with oil cooled brakes & steering clutches s/n 15A1673-up
D8H 35A is a Torque Converter Drive
D8H 36A is a Direct Drive
D8H 46A is a Power Shift
Mon, Nov 30, 2015 6:33 AM
7upuller
Hey OldMagnet,
I could be wrong, but the 15-a started as a D8D model with Dry brakes, then became the D8-G model at serial 1673 with wet brakes.
The 14-a was the D8-E model with dry brakes and at serial 3861 became the D8-F model wet brakes.
So I can track the D8-D,E,F,G,H models and so on. Did they have a B and C model D8's?
Mon, Nov 30, 2015 6:40 AM
Reply to 7upuller:
Hey OldMagnet,
My best source shows the change for the 15A1673 but does not give it a "D" designation. No use of B & C for D8's
I see the "D" designation for the early 15A in the ACMOC s/n book.
Mon, Nov 30, 2015 6:51 AM
Reply to 7upuller:
Hey OldMagnet,
The series production started in late 1959 for the D4C D6B tractors and in 1955 for the D7C,D8E and D9D tractors.
Mon, Nov 30, 2015 6:52 AM
7upuller
Hey Gang,
As I know it;
RD8 5E series 32 produced, 1935 with 108 hp
RD8 1H series 9999 produced from 1935 to 1941 with 108 hp
RD8 8R series 9999 produced from 1940 to 1945 with 131 hp
D8 2u series 23,537 produced from 1945 to 1952 with 148 hp
D8 13a series 3703 produced from 1953 to 1955 with 180 hp
D8D 15a series 1672 produced from 1955 to 1956 with 191 hp, dry brakes, TC drive
D8E 14a series 3860 produced from 1955 to 1956 with 191 hp dry brakes, Direct Drive
D8F 14a series 3861-9692 from 1956 to 1958 with 191 hp wet brakes, boosters, Direct Drive
D8G 15a series missing number 1956 to 1958 with 191 hp wet brakes, boosters, TC Drive
D8H 35a Series 776 produced 1959 to ? with 235 hp TC Drive
D8H 36a Series 4648 produced 1959 to 1966 with 235hp Direct Drive
D8H 36a Series 4649-5600 1966 to 1972 with 270 hp Direct Drive
D8H 46a Series 12,883 1959-1966 with 235 hp, Power Shift
D8H 46a Series 12,884- between 32-33,000 270 hp, Power Shift
D8K series starts 1973 300hp
There were some D8H models when first started that had 225 hp I think, don't know amount. My list is USA builds only. Feel free to add or correct. Most of this info I have taken from this BB.
Mon, Nov 30, 2015 9:20 AM
Reply to 7upuller:
Hey Gang,
As I know it;
RD8 5E series 5E8001 to 5E8033 1935 115hp
RD8 1H series 1H1 to 1H1496 1935 to 1936
RD8/D8 1H series 1H1497 to 1H2726 1937 s/n of change from RD8 to D8 unknown 115hp
D8 series 1H2727 to 1H9999 1938 to 1941 115hp
D8 8R1 to 8R9999 produced from 1941 to 1945 with 132 hp
D8 2U1 to 2U23,537 produced from 1945 to 1953 with 132 hp
D8 13A1 to 13A3703 produced from 1953 to 1955 with 186 hp
D8D 15A1 to 15A1672 produced from 1955 to 1956 with 191 hp, dry brakes, TC drive
D8E 14A1 to 14A3860 produced from 1955 to 1956 with 191 hp dry brakes, Direct Drive
D8F 14A3861 to 14A9692 produced from 1956 to 1958 with 191 hp oil cooled brakes & steering clutches, Direct Drive
D8G 15A1673 to 15A3383 produced from 1956 to 1958 191hp oil cooled brakes & steering clutches, TC Drive
D8F(Military) 9A1301 to 9A2262 1956
D8H 35A1 to 35A776 produced 1958 to 1961 with 225hp to 35A434, 235hp 35A435-up TC Drive
D8H 36A1 to 36A5722 produced 1959 to 1974 with 225hp to 36A1228, 235hp 36A129 to 36A4648, 270hp 36A4649-up, Direct Drive
D8H 46A1 to 46A34086 produced from 1959 to 1974 with 225hp to 46A3043, 235hp 46A3044 to 46A12884, 270hp 46A12885- up, Power Shift
D8K 76V1 to 76V1034 produced 1974 to 1984 300hp Direct Drive
D8K 77V1 to 77V18848 produced from 1974 to 1984 300hp Power Shift
Mon, Nov 30, 2015 12:18 PM
