D6 oil pan troubles
D6 oil pan troubles
sodbuster25
Send a private message to sodbuster25
I'm working on a 1952 D6 dozer. I am having a problem getting the oil pan off the block. I have all the bolts out and I drove the dowel pins out. I have beat on it, pryed on it, and tried to drive a wedge between the block and the pan and it still wont move. Any ideas?
Thu, Dec 27, 2007 1:32 AM
Jeff M.
Is it out side? It may have I ce in it and around the pickup tube.
Thu, Dec 27, 2007 1:52 AM
Reply to Jeff M.:
Are you sure you got all the bolts?
There are:
30 -7/16 x 1-1/8 pan bolts
4- 1/2 x 1-1/2 bell housing bolts
7- 3/8 x 1-3/4 bolts into the timing cover
With all these out it's a clear drop but you have to drop or remove the equalizer spring bracket to get it out.
Thu, Dec 27, 2007 2:43 AM
sodbuster25
There are:
Thanks for the reply! It is inside in the heat! Do all of the bolts that screw into the timing cover come up from the bottom?
Thu, Dec 27, 2007 8:03 AM
Reply to sodbuster25:
Yes, all from the bottom.
Are you sure on the year model??? the earlier D4600 "R" series tractors have some "juggle" requirements to get the pan off.
Thu, Dec 27, 2007 8:21 AM
sodbuster25
serial # is 9U10453. I was told its was a 1952. Is that right? I will check the bolts again in the morning. This thing just will not break loose! Thanks
Thu, Dec 27, 2007 8:33 AM
brian18a
Sure someone did not glue it on with something like Cat super gasket cement, if so it is almost impossible to get things apart.
Thu, Dec 27, 2007 10:59 AM
Year and model is correct.
Pull the side covers off and have a look in there to see if anything is hanging it up. I'm stumped😕 😕
Are all the bolts accounted for??
Thu, Dec 27, 2007 11:02 AM
sodbuster25
Turns out it was just the gasket that was glued on! I used the torch to burn the gasket out and then soaked it with WD-40. After about 2 hours with a pry bar, the pan finally broke loose! Thanks for all the help!
Fri, Dec 28, 2007 11:45 PM
| Hartley - South Australia
