cat d 315 fuel issue
Showing 1 to 10 of 14 results
insley 54
Send a private message to insley 54
Changed the four fuel filters in housing. Someone mounted a filter between the tank and the pump. My other engine does not have this. I wonder ...if I should bypass it . Not getting fuel . The engine has been sitting ,turns over nicely.
Thu, Nov 5, 2015 5:29 AM
Inter674
these engine often need to be force fed the fuel to get it to bleed out and run. Try applying a light pressure to the tank and open up the bleed valves both on the pump and elsewhere.
Thu, Nov 5, 2015 5:54 AM
Reply to Inter674:
its better to have a filter between the tank and transfer pump--will collect all the crud from the tank
systematically check fuel flow from tank.from transfer pump,from fuel filters,from injectors
Thu, Nov 5, 2015 6:10 AM
ag-mike
Reply to dpendzic:
tap ur fuel cap and use a valve stem with matching threads, pressure ur tank, like about 15-25 pounds, bleed system with compressed air is the trick i use. dans right, leave filter.
[attachment=31939]SAM_2940.jpg[/attachment][attachment=31940]SAM_2941.jpg[/attachment]
Thu, Nov 5, 2015 9:59 AM
d9gdon
Where are you not getting fuel, at the transfer pump or the filter housing or at the injector pumps or at the injectors?
Thu, Nov 5, 2015 6:13 PM
Thank you received: 19
Reply to ag-mike:
[quote="ag-mike"]tap ur fuel cap and use a valve stem with matching threads, pressure ur tank, like about 15-25 pounds, bleed system with compressed air is the trick i use. dans right, leave filter.
[/quote]
That's to high a pressure and will balloon your tank. 5-10 psi max is what I would recommend and even 10psi is high. (figuring all those square inches of tank surface)
Fri, Nov 6, 2015 12:57 AM
old-iron-habit
[/quote]
I use a rubber pipe cap 4" or 4-1/2" I think. Measure to be sure. I glue a valve stem into it. No clamp on the tank. It fits tight enough to hold enough pressure to bleed the system and if you go nuts and get to much pressure it will simply blow off with no harm done. Your cap will still be original also.
Fri, Nov 6, 2015 7:02 AM
insley 54
I used my air compressor to help bleed the filters, Worked fantastic! Cracked the nuts feeding the injectors threw the compression release and the engine ran wide open! The throttle was about a quarter open. The shut off did not work, Released the line from the tank to the first filter and she ran out of fuel. Wow had no idea a d 315 could spin over so quickly, What do you think happened? Is the governor not working? I have a spare engine with another injection pump. This is powering my 1954 insley crane Thanks for the help
Mon, Nov 9, 2015 6:00 AM
Reply to insley 54:
OOPS! Sorry! We should have mentioned that pressurizing and bleeding is done WITHOUT the engine running! :doh:
Mon, Nov 9, 2015 6:06 AM
insley 54
Reply to Inter674:
I replyed to my own thread...I thank everyone for the help....please look at the last thread to see what happened
Mon, Nov 9, 2015 6:08 AM
insley 54
Reply to drujinin:
I only used the air to prime the system..
Mon, Nov 9, 2015 6:16 AM
