Greasing Balls
Greasing Balls
Showing 1 to 10 of 17 results
Oil Slick
I got several pickups with the 2 5/16 goose neck ball. I keep them greased but a fellow told me there suppose to be ran dry. Having dry balls sounds like to much friction causing wear. Should the balls be lubed or ran dry?
Thanks.
Fri, Oct 16, 2015 9:12 AM
Sasquatch
I grease the gooseneck ball on my truck, I'm not saying it's the right thing to do or the wrong thing to do (nobody's ever told me a reason not to) but in my mind I would think there would be accelerated wear to both the ball and hitch if ran dry all the time, more so if you have a load that puts a lot of down pressure on the hitch.
Fri, Oct 16, 2015 9:28 AM
janmeermans
Reply to Sasquatch:
Mike,
I wonder when "they often itch without oil" will enter this conversation? Oh, maybe it just did!
Jan (😊)
Fri, Oct 16, 2015 9:40 AM
mog5858
Online
Reply to janmeermans:
Mike,
Jan (😊)
I grease my gooseneck ball too. it keep's it quieter if you ask me plus it slides on and off a little easier. it help's when you are doing a hi speed back up to get a piece of old iron too. lol
i bet the guy that told you that like too keep his stuff too clean or he would never have to worry about wear because he really dose not do much with it.
Fri, Oct 16, 2015 9:51 AM
4tcompost
Send a private message to 4tcompost
Mike,
Jan (😊)
Glad I'm not the only one who overthinks stuff!!!! I had the same thought. Here we go, your KW 5th wheel has grease, your low bed king pin & plate has grease. What's the difference with the ball hitch set up? None that I can see. Thanks ROY
Fri, Oct 16, 2015 9:53 AM
mrsmackpaul
Reply to mog5858:
was any reason given as to why you would run it dry ????
I would have thought you would always grease it maybe it has a nylon insert or something like that
Paul
Fri, Oct 16, 2015 10:01 AM
Paso Bob
Reply to 4tcompost:
I've never greased mine. It's anodized and has a nice shine to it. I don't know anyone that greases the 2 inch bumper hitch balls either, just sayin...
Fri, Oct 16, 2015 10:04 AM
Sasquatch
Reply to Paso Bob:
Lol actually I grease the bumper hitch and receiver balls too, so that makes one person you've ran across that does. Mog mentioned the potential mess of having grease on a gooseneck ball hitch being an inconvenience - I solved that problem by cutting the top half of a plastic 20oz Coke bottle off and using the bottom half of it to grab the ball with; the contour of the plastic bottle slides down over the hitch ball and fits nicely, keeps the grease off your hands/gloves, and slides back off easily after reinstalling the ball into the hitch. I also keep it on the ball when it's out of the hitch and in the small storage box I made for it, keeps the inside of the box clean and I don't have to worry about it getting grease all over the back seat of the truck. Can you tell I'm a little OCD about it all? Haha.
Fri, Oct 16, 2015 10:37 AM
ShawnStover
Send a private message to ShawnStover
Reply to Sasquatch:
I've always kept my balls, uh, greased. Both the bumper hitches and the goosenecks. It may be a small inconvenience to have grease on them sometimes, but I think it pays off in the long run. I've actually had a ball work itself loose on a bumper hitch before, because the friction was so great it worked against the nut. That may be a freak incident, but I've never had another problem since by keeping them lubed.
Fri, Oct 16, 2015 11:03 AM
Inter674
Reply to ShawnStover:
but what about the dust it accumulates and acts like grinding paste!
Balls should be kept dry:tsk:
Fri, Oct 16, 2015 11:26 AM
Wombat
Donor
Reply to Inter674:
I always like to keep mine well lubricated, makes for much easier coupling and more gentle on the mating parts, if you are really worried about it becoming too messy, maybe try a good dry type, spray on graphite product.
Fri, Oct 16, 2015 11:38 AM
Price Tractor Pull
Price Tractor Pull
