Starting 600 amp Cat welder video
Showing 1 to 10 of 20 results
old-iron-habit
Started the "new" welder yesterday. Held the preheat for 40 seconds and then hit the starter. Not sure if the preheat is working properly, as the second time I started it after it was warmed up, it still cranked a bit. Fuel tank is mostly full of offroad fuel. No telling how old it is. Engine tag says Power Unit, Serial # 51B2958. Series number H. Does anyone know what engine book would cover the powerplant portion of the welder. I believe it to be 1963. The lincoln welder end serial # check out to 1963 also.
Thanks in advance.
Roger
https://m.youtube.com/watch?v=qijBnbgmMm8
Thu, Oct 15, 2015 4:14 AM
oldtanker
Send a private message to oldtanker
[quote="old-iron-habit"]Started the "new" welder yesterday. Held the preheat for 40 seconds and then hit the starter. Not sure if the preheat is working properly, as the second time I started it after it was warmed up, it still cranked a bit. Fuel tank is mostly full of offroad fuel. No telling how old it is. Engine tag says Power Unit, Serial # 51B2958. Series number H. Does anyone know what engine book would cover the powerplant portion of the welder. I believe it to be 1963. The lincoln welder end serial # check out to 1963 also.
Thanks in advance.
Roger
https://m.youtube.com/watch?v=qijBnbgmMm8[/quote]
OK where is the video of you welding with it????
Rick
Thu, Oct 15, 2015 5:13 AM
old-iron-habit
Reply to oldtanker:
Thanks in advance.
Roger
Rick
[quote="oldtanker"]OK where is the video of you welding with it????
Rick[/quote]
It will be coming. Both welders have a 3 position switch that say straight, off, and reverse polarity. They are both in the off position. I am trying to find out if I switch them with the engine running, while shut off or? Maybe it don't matter as long as it is not under load, but I don't want to wreck anything.
Thu, Oct 15, 2015 6:51 AM
JoeG
Send a private message to JoeG
Reply to old-iron-habit:
Rick[/quote]
Now I want one!!! I would say you could probably switch the polarity around with it running as long as it isn't under load as you say Roger, the load comes when the arc gets struck.
Thu, Oct 15, 2015 7:52 AM
Rick[/quote]
Need to look for the D311 51Bxxxx series service manual to cover the engine.
ag-mike
nice, real nice. heres my posting at weldingweb on the Lincoln page, good info there.
http://weldingweb.com/showthread.php?537581-I-became-caretaker-of-Caterpillar-D315-Lincoln-300x2-Twin-Arc-welding-machine-today
Thu, Oct 15, 2015 7:01 PM
old-iron-habit
Reply to ag-mike:
[quote="ag-mike"]nice, real nice. heres my posting at weldingweb on the Lincoln page, good info there.
http://weldingweb.com/showthread.php?537581-I-became-caretaker-of-Caterpillar-D315-Lincoln-300x2-Twin-Arc-welding-machine-today[/quote]
Ag-mike, Thank you for the link. I am going to join that forum. Lots of good welder stuff there.
OM, As always, Thank You for the prompt and knowledgeble advice. I will look for the books.
Thu, Oct 15, 2015 10:44 PM
Is good after you figure out who really welds and who thinks they weld!
Fri, Oct 16, 2015 1:42 AM
7upuller
Reply to drujinin:
Hey OldIronHabit,
I went to my stash of books from the South Pole auction. Look what I found. Send me a PM with your mailing address and I'll fed ex it to you. Give me some models numbers on your welder, I may have that book too. Old Magnet would be in heaven looking at my stash... Hahaha... Offer still stands Old Magnet. Come take what you need.
Glen[attachment=31661]image.jpg[/attachment]
Fri, Oct 16, 2015 4:59 AM
old-iron-habit
Reply to 7upuller:
Hey OldIronHabit,
[quote="7upuller"]Hey OldIronHabit,
Glen
[/quote]
Gosh, Thanks Glen. Will PM address. The welder is a Lincoln Shield Arc Welder, Type SAE-300X2. Looks like it came from a prison according to one tag on it.
Fri, Oct 16, 2015 6:23 AM
7upuller
Glen
[/quote]
Hey OldIronHabit,
Your just getting way too much Kool old stuff. I got your text, I dumped my Can, it's empty. Alright, I'll look in my crate of books for welder info. I know the collection had a lot of Generator, and welder books. I'll look and let you know. I'll have Jennifer Ship the 311 book tomorrow or Monday. I laughed when reading your post about your flatbed truck. I said to my Self, "Self, Roger should build living quarters." I guess I read that one correct, as your next post your admitted your plan. Have fun with your projects.... glen
Fri, Oct 16, 2015 7:25 AM
| Hartley - South Australia
