1984 3406B injector pump question
Showing 1 to 10 of 19 results
chriscokid
i am helping work on a 1984 Caterpillar truck engine for a friend of mine and he is having problems with his injection pump housing.
8n9365 is the pump number.
Question, if the solenoid is working and we have fuel to the pump housing but no pressure at the lines then it would be a stuck rack?
Would this rack (if the problem) be similar to the ones in Track type tractors?
Would anyone have a parts breakdown?
He plans to make a toy hauler out of it, not put it to work, it has been setting for 15 years.
Any help is appreciated.
Wed, Oct 14, 2015 6:37 AM
bob
Send a private message to bob
Erik, could you post a couple of pic's of the pump side and the governor and I will try to help you.
Later Bob
Wed, Oct 14, 2015 9:15 AM
catsilver
Reply to bob:
Later Bob
The rack must be pulled to the 'shut-off' position for fuel to get past all the pumps and open the non return valves to get into the injector lines.
Wed, Oct 14, 2015 1:29 PM
chriscokid
Reply to catsilver:
i will get pictures today, there is a small amount of fuel exiting from the return line. and when i crack the fuel lines from the pumps it only weeps fuel, it seems to not have any pressure.
Wed, Oct 14, 2015 5:11 PM
catsilver
Reply to chriscokid:
It will only weep fuel from the injector lines if you are hand priming, there may not be much from the return line, especially if it is an orifice controlled pressure system which depends on transfer pump flow to keep pressure up, if you can get pressure with all the air purged out, you should have fuel to start. try taking the shut-off solenoid off completely to see if it will start then.
Thu, Oct 15, 2015 2:43 AM
chriscokid
Reply to catsilver:
I put a new transfer pump on and hand primed it, then cranked it on starting fluid to see it she would go, when engine is whirling still no pressure.
I will try removing the solenoid to see if that makes a difference.
Thu, Oct 15, 2015 5:08 AM
Willowhic
Send a private message to Willowhic
I was having similar trouble with my 3406 re-powered 980. Turns out the problem was the plunger-to-housing O-ring seal on the hand priming pump. The O-ring had cracked over time and was allowing air to get sucked in by the transfer pump. The presence of air prevented the suction and pressurization of fuel. The solution was to remove the cracked O-ring from the plunger and stretch a new one over the knob, simple as that.
Good luck! hope this helps!
1988 JCB 1400B backhoe
1966 Cat D9 cable dozer
1966 Cat 980 wheel loader
1967 Galion 140 grader
1963 Cat D7E hydraulic dozer 47A886
196? Cat 112 grader 3U3308 (engine: 3U243)
Thu, Oct 15, 2015 8:27 AM
chriscokid
Reply to catsilver:
I tried that and get the same reaction.
you can hear the fuel dump via the return line back to the tank.
I assume that there is a rack that would be connected to the throttle control? and if this rack is stuck in the closed position then fuel would dump in the return line?
Fri, Oct 16, 2015 7:10 PM
Don't know anything about Cat truck engines but here is about the best picture I could find.
Fri, Oct 16, 2015 10:19 PM
Hi Eric,
the 3406B injection pump is the same scroll (Bosch) type setup as any Cat pump. This is NOT a Sleeve Metering style pump--can be confused as such due to the plate on the side.
The plate on the side is the fuel gallery that the injection pumps draw from and indeed pump back into when the rack is in the stop position.
Rack is likely stuck or a pump and its lifter is stuck up. If a lifter is stuck up the pumps bottom plate will need to be removed to see if you can get to the lifters to pull them down --this action should release the pump plungers/rack
As suggested remove the stop solenoid and see if it is stuck in the shutoff position.
Also remove the Air Fuel Ratio Valve and see if the linkage it connects thru is stuck.
Thru the oval 2 bolt cover at the front (left in the scan) side of the pump body (circled in red on OM's pic scanned below--Thanks OM) you should be able to get to one end of the fuel rack and see if you can gently move the rack and also see if any moisture has been in there.
There can be a separate manual shut off shaft out the side of the Governor housing that could be stuck too, or allow you to gently move the rack.
The fuel coming from the pump bonnets is slow because the delivery valves in these direct injection pumps is a dual valve affair that has a secondary return valve in it to allow return pressure spikes to return to the pump side of the valve, both sections of the valve have a very strong spring in each section--not weak one like the old pre-chamber pumps have.
The main part of the delivery valve has a groove machined in its sealing face to allow leakage back also and the fuel you are seeing comes thru that groove--the delivery valves are not a positive seal like say a Bosch type delivery valve.
The fuel return orifice/valve allows about 9 gals an hour to return to the tank to keep the pump cooled and bled of any air that may build up in the supply gallery and hinder injection.
Hope this helps.
Sat, Oct 17, 2015 6:32 AM
Reply to edb:
Hi Eric,
Hope this helps.
Is this a scroll type pump or sleeve metering unit? If sleeve metering, there is no rack.
Sat, Oct 17, 2015 7:53 AM
