Caterpillar 28 crawler tractor
Showing 1 to 10 of 18 results
Nbrown
Send a private message to Nbrown
Good evening all. New to the forum. I might ave an opportunity to pick up A28 Cat crawler tractor. The machine has been parked inside for what looks to have been quite a while. Please provide any info on these that you can share. The tractor seems to be complete. I was told to make an offer and don't even know where to begin. Any thoughts. I know pictures will be helpful and I will do what I can to get them up. Thanks in advance. Nate
Tue, Sep 15, 2015 5:21 AM
Thank you received: 40
Hi, Nbrown.
Welkum too ther 4um.
Your location would probably help in giving you a ball park figure for that 28 as values vary quite a lot in different places around the globe.
Tue, Sep 15, 2015 7:14 AM
Nbrown
Hi, Nbrown.
I'm in Plymouth CT
Tue, Sep 15, 2015 7:22 AM
Steve A
Reply to Nbrown:
I'm in Plymouth CT
The 28 is the newest of the Twenty series, it started as a Twenty, then the Twenty five and then the 28 with minor changes. If its wide or has accessories it adds to the value. The condition of the tracks and UC also makes a difference, posting a few pictures will help a lot.
Also check the manifold for condition and check to see if the engine is stuck,
I have a wide one in my shop with the engine on a hoist as I type this reply.
Tue, Sep 15, 2015 8:58 AM
Nbrown
Reply to Steve A:
Here are a few pictures that I could get when I was last there. It appears the previous owner backed it in I'm told 30 plus years ago to but the blade on and really never went any further then getting it lined up. After moving things that were all around it and piled on top I found the hand crank. It did turn so I thought that was encouraging. Hoping to have it home by the end of the weekend.
[attachment=31433]image.jpg[/attachment][attachment=31434]image.jpg[/attachment][attachment=31435]image.jpg[/attachment]
Also if anyone might have use for the blade let me know. I'm sure we can work something out.
Fri, Oct 2, 2015 10:01 PM
Reply to Nbrown:
A Mill and a Shaper in the left of those photo's. Quite the collection of Treasure!
If the opposite side of the tractor looks as good. I'd say you done exceptionally well to acquire it! As old Gas tractors are typically found in some shade of rust and faded yellow! Good to see the blade project was never finished, no sense in tearing up a Good Ag CAT!
Sat, Oct 3, 2015 1:07 AM
Nbrown
Reply to drujinin:
Thanks. This was a 47 acre property of three generations that never went to the dump and by the looks of it were rather handy. I don't know where to start with what I saw there.
Sat, Oct 3, 2015 5:50 AM
Dandy Dave
Send a private message to Dandy Dave
Reply to Nbrown:
A cat 28 eight is fairly rare. They did not build a lot of them. Nice that it is inside and will probably run without a lot of trouble. If I was there and the price was reasonable, it would already be in my shop. Well, maybe not right away as my shop looks about like what you see in the photos plus. LOL. Scrap price is always a starting point. Dandy Dave!
Sat, Oct 3, 2015 6:37 AM
Thank you received: 22
Reply to Dandy Dave:
Need some closer photos, especially of the exhaust manifold. What's that shiny silver gadget underneath the water pump? I'm guessing the hydraulic pump that he never got around to using?
Measure the distance across five track pins and the members will tell you how worn it is. Potentially useful for negotiating.
Sat, Oct 3, 2015 8:40 AM
Nbrown
So I got it out of the building. Any info would be appreciated. 4F1093 is from the tag on the engine.
Tue, Oct 6, 2015 5:04 AM
Reply to Nbrown:
Over all, it looks like new(almost)! Nice save, now get it running! It shouldn't take much as it looks really Good!
Tue, Oct 6, 2015 7:17 AM
