Tumblebug Scraper and D2 Video
Showing 1 to 10 of 10 results
Sasquatch
Hey everybody I decided to put my little GoPro camera to use and make a short Youtube video of my little tumblebug rotary scraper before I put it away for the winter, I decided to use it to pull some sandy soil back uphill on a small access road that had washed out in a previous rain storm. It worked really well for the task, after the material was redeposited I graded the road out in preparation for a layer of new gravel. I just used a 4 foot long pipe clamp as a camera stand, clamped it onto the scraper frame in a few different spots to give several different angles of the scraper operating. I attached the camera to the upper end of the clamp with the tubular mount attachment I got with it, worked pretty well. A couple of spots get a little shaky from the scraper bumping around but I think it turned out well for the most part. Hope you guys enjoy the film.😛op2:
https://www.youtube.com/watch?v=E008mXrCqVE
Thu, Sep 10, 2015 11:08 AM
old-iron-habit
Good video Sasquatch. By being able to carry a bit od dirt along it is amazing how much work them little tumble bugs can do cleaning up a road and fixing erosion ruts and water holes.
Thu, Sep 10, 2015 11:39 AM
mrsmackpaul
Reply to old-iron-habit:
great little unit it is amazing what can be done with these little scoops
good video and thanks for sharing
Paul
Thu, Sep 10, 2015 4:29 PM
Reply to mrsmackpaul:
Paul
Very Nice Video!
While only having seen one in operation from a distance, it never looked practical.
Watching this video with the explanation of how it works and how to adjust it to operate properly makes it a very practical and useful tool!
Almost makes a guy want to put it on his list of accessories to buy!
Thanks for the Great video!
Thu, Sep 10, 2015 6:42 PM
janmeermans
Reply to drujinin:
Very Nice Video!
Sas,
Great explanation and demo on how they work. Like Jeff, I have never seen one working to the extent that I know how they work. You should have fired up and got into the sandbox at the show. Maybe you did and I just did not see you out there.
Keep your camera bracket handy so when OIH gets his DW 21 going, we can watch his bowl load and dump too.
Jan
Thu, Sep 10, 2015 7:24 PM
cojhl2
Reply to janmeermans:
Sas,
Jan
Great Video and Presentation!:clap2:
Thu, Sep 10, 2015 8:32 PM
mog5858
Reply to cojhl2:
great job well done as usual. glad to see you got a it a little shined up before putting away for the Winter. now this makes my wont to go hook my up and go play with it. p.s did you get any pic's of me ridding the fire plow?
Thu, Sep 10, 2015 9:20 PM
Sasquatch
[quote="janmeermans"]Sas,
Jan[/quote]
Thanks Jan, I never took the scraper to the sandbox at the show because I figured it would look a bit comical out there just nibbling on the loose windrows that the "real" scrapers left when they loaded, was content to sit it out on the sidelines. I'll be sure to get some footage of o-i-h's DW21 filling the bowl just for comparison, there'll be a bit more dirt to watch boil in that one, lol.
Thanks Martin, unfortunately I did not get any pics of the plow in action but I think I saw jbernd snapping a couple or maybe even taking a video of you operating it in the ground, I'll check with him to see if he has anything.😛hoto: The video I wish I would've took was when you and Garlic Mom saved the parade on Saturday by assisting the stalled roller off of the route with the blade of o-i-h's D2. The applause from the crowd after the stalled roller was helped to the top of the hill was pretty cool.:clap2:
Fri, Sep 11, 2015 9:08 AM
thomas84
Send a private message to thomas84
Great video, I enjoyed watching it. As already mentioned I have never thought these would have been practical but you were moving quite a bit pretty fast.
Fri, Sep 11, 2015 9:09 AM
Sasquatch
[quote="Garlic Pete"]I never really understood what the "extra" lever did. I could see that on all the tumblebugs I've seen it changes the geometry of the tongue and pivot stops, but I didn't understand the relationship to the cutting edge and making it ride over the material or dig into the material.
Your video makes it all clear now. I have Tom Madden's 10' tumblebug at my house, with the assignment to figure out how to make it work behind a Sixty. With this video, I think I can finally get things adjusted and the darn thing working. The previous owners must have been using it as a grader, so all the stops are set in odd places, making trying to logic out operation that much more difficult.
I enjoyed talking to you at the show and look forward to seeing you again soon.
Pete.[/quote]
Thanks Pete, each tumblebug I have is slightly different in adjustment but the basic principal is the same - transport, cut, carry, dump (all at once with a complete revolution or spread with just half a revolution) then back to transport to start the process over again. The quickest way I've found to adjust them to a machine's drawbar is to hook up and pull tension on the hitch. With the slack tightened up get the transport stop adjustment set for it to ride squarely on the wear shoes, then trip it to rotate the bowl forward and again with the hitch tensioned set your cut/carry stops for the best range you can get for the cutting edge both into the dirt and out of the dirt when manipulating the loading lever. Sometimes for a more aggressive cut you might have to compromise on the distance the cutting edge will raise from the ground when carrying, but like I said all models differ in range of adjustability. With that said, I've never played with one that had wheels on it, I don't have any that big but I imagine the principal is still the same. But the thing to remember is that whenever you hook to a machine with a different drawbar height, re-adjustment of the stops is necessary.
*Edit* Forgot to mention, the cheaper scrapers that were sold back in the day did not have a variable pitch loading lever like the nicer ones did. Their loading lever just actuated an over-center mechanism that pitched the bowl forward to cut at a pre-determined amount every time. To stop the cut you usually had to stop the machine and slack the hitch to re-set the mechanism and re-enter carry mode (I've got a small Montgomery-Wards one like that). The fancier models were a lot easier to use because like the one in the video, the farther you pulled the load lever the deeper it would cut - made it a lot easier to feather into a grade.
Fri, Sep 11, 2015 9:20 AM
Jack
Reply to Sasquatch:
Pete.[/quote]
I haven't seen one of those in action since I was aged in single digits. Thanks for a trip back.
A relative had one he pulled with an AC model M. He managed to dig a basement with it on gentle sloping land. The house is there yet; it didn't fall into his basement. Right after the war a bulldozer was hard to find and a backhoe was non-existent. Bill managed quite nicely with what he had.
Good job on video. Again, thanks!
Fri, Sep 11, 2015 10:40 AM
Earlcoate Charity Open Day
