Valve adjustment, Intake and Exhaust is 0.012 hot (or 0.010 cold).
Firing order is 1-3-4-2.
Thank you so much, I really appreciate the info.
Lance
Hey OM, I thought cold was always more than hot. should it be the other way around??
george
george
20 THOU. on the decompresion lifters...
I don't have any specific info on the D8800 valve clearance, but I always was told the standard recommendation for all CAT engines of that era was 0.010" HOT on both intakes and exhausts. The 0.012 was a preliminary setting when getting ready to run a newly repaired engine to approximate the final setting.
Tough group!!!!
Valve clearance hot, right out of the D8800 manual is 0.012 in.
0.010 cold was recommended by SJ, that's good enough for me.
Compression release clearance 0.025 - 0.030 in. again right out of the Cat manual.
.011" warm-.08" Antarctic fricken cold.
lol just had to add that.
Gary
