D2 fuel bypass valve
Showing 1 to 9 of 9 results
tomwalter
Send a private message to tomwalter
Hi all
I have low pressure when cranking my D2 SN 4U5820. Starting was always easy before I took my D2 apart to replace the steering clutches. While attempting to drain the fuel filter tower I accidentally removed the bypass valve plug mistaking it for the filter tower drain. I put it back together but now when cranking to start the gauge only sits at around 1 quarter of the full pressure at best and is hard to start. Pressure is fine when running. I have read many threads about fuel bypass valves and am fairly certain this is my issue.
I went to my local Cat dealer and tried to order a new spring but found that the bypass setup in the book looked different to mine. I bought a spring of similar size and dimension and fitted but no difference. Tried stiffer spring still no difference.
My question is based on the pictures attached can you tell ne what this bypass/fuel transfer setup is and how it should seal. There was no rubber seal around the plunger when removed although it did fall out and may have rolled away. If there needs to be one where does it seat? The last picture is from around a D4D that the dealer got out for a look which looks to be more like what I have. Any help would be much appreciated.
Tom
Tue, Aug 11, 2015 6:53 PM
The gauge reading 1/4 while cranking is within normal limits. I doubt it is the reason for hard starting
If your valve is missing a rubber, it will be attached to the little poppet that sits on top of the spring. On the other styles of bypass valves, the rubber will get hard and fail to seal properly and in extreme cases the cast iron seat can even get worn.
Tue, Aug 11, 2015 9:53 PM
tomwalter
ok maybe need some more bleeding of the fuel system.
Does anyone know what this setup is? The pump looks to be the correct one but the bypass system looks nothing like anything in the parts book. They all show a cover with 2 bolts holding the plunger and spring not a plug like mine has.
Thu, Aug 13, 2015 4:17 PM
Inter674
Reply to tomwalter:
my limited experience is such that I think this system requires some positive pressure to be placed on the tank via the filler to fill and bleed the system efficiently. You can spend an awful amount of time otherwise waiting for the system to fill and bleed by gravity assisted by the weakish pump system.
Thu, Aug 13, 2015 5:45 PM
Dandy Dave
Send a private message to Dandy Dave
Reply to Inter674:
The transfer pumps I have had apart in the past off of similar machines have a Packing for a seal. There is a spring and washer that pushes against it. It looks a lot like old time graphite water pump packing. On the by pass valve. It needs to seat correctly. Any dirt, which is not uncommon in these 50 and 60 + year old machines, and it will not seat. On hard starting, Have you changed your fuel filters??? These old cats will run on a gravity feed from a 5 gallon jug set on the hood and fed in reverse though one of the bleeder valves. I've done it before. One case in particular was on a D8D with the fuel oil driven clutch as it takes way too long to fill that torque converter and the filter housings by running the pony alone. Dandy Dave!
Thu, Aug 13, 2015 7:04 PM
If your engine serial number matches the chassis serial number, then only thing I can think is someone found a more modern pump that would substitute for the old style. If serial numbers don't match the engine might be a transplant.
Seems to be a perfect fit.
Thu, Aug 13, 2015 9:04 PM
That bypass valve arrangement looks like what is used on the very early D2 J models and the D4 4G series. The plunger does not appear to have a resilient seat.
Plunger part number is a 4B519
Spring part number is 4B517
Thu, Aug 13, 2015 11:30 PM
Hi Tom,
the pump parts picture is from a D4D 78A.
As was said above maybe your pump or engine is a transplant from a later Industrial engine or some other application like the 212 Motor Grader that uses that style transfer pump.
I do understand that your transfer pump is different to the old style shown in your parts book--does the D4D plunger not fit your pump? I am not sure what, other than the cited pump difference, your question is.
Have you tried the D4D relief valve yet for suitable fit.
From memory, the old black plastic button type RV plunger is superseded by the rubber seat steel plunger and should work, also those new style rubber seat plungers come in at least 2 sizes which may be your problem. The one used on D343 engines I think is smaller and is P/No 8M0874.
A lot of starting problems arise from not Fully bleeding air from the fuel system.
There are little bleed valves at the rear of each injection pump body that it is essential to bleed all air from several times until air free fuel issues from the drain ports at the rear of said pumps.
You need a tool like a socket that is used to hold auto shock absorber studs with, they have 2 flats the same size as the pump bleeders.
There is a special Cat tool for the job, P/No 9F0022 Wrench, I believe that Cat now supply these sockets instead--likely cheaper at an auto parts store.
Hope this helps.
Fri, Aug 14, 2015 8:09 AM
Inter674
Reply to edb:
Hi Tom,
Hope this helps.
...another problem I encountered was that the gasket fitted to the top cover of the filter tower was found to be wrongly installed which caused low fuel pressure and fuel to constantly drip from the overflow pipe.
I'm still not sure how this caused such problems but when a new gasket was fitted correctly it cured both problems!
When I have some time I will examine the system to see why - but I did note a small hole in the tower that supposedly connected to another in the lid and which was blocked off by the wrongly fitted gasket.....Conversely the gasket was not sealing correctly probably causing a short circuit and allowing fuel to pass into the overflow pipe.
By then I had spent several hours pulling everything apart - including the pump and was about to embark on a full pump re-build.
I guess the point is.... never presume everything is correctly fitted...
Fri, Aug 14, 2015 8:28 AM
tomwalter
Reply to Inter674:
Thankyou all for your feedback
My engine has the 4U serial prefix and the serial on the transmission is missing so I am fairly confident that the engine is at least from a similar machine if not original. I have bled the injector pump through the small valves that require the special tool but used a very small spanner but maybe more bleeding is required. I will try an inner tube over the fuel cap to give some pressure.
I did order the spring from the D4D as shown in the last picture but it was far too large leading me to think that the plunger would be also. I might try the plunger listed by OM. My original question was is there meant to be a rubber seal on the plunger but OM says there should not.
I have changed fuel filters which were covered in gunk and installed new gaskets. I did take special care to align the small hole in the bottom gasket and im pretty sure ive got this right as once started the engine runs fine with pressure at the top of the gauge when working and in the caution when idleing.
Sat, Aug 15, 2015 4:33 AM
