Might be helpful to somebody some day.
Thank you received: 37
Hi, Folks.
This information is easy enough to find on the 'net - drill sizes for tapping various threads - but I thought I'd post a link to one such site here so that those of you who are interested can go there, copy and paste the chart onto an MS Word page, print it out and have your very own chart up on the wall of your workshop for when you NEED it.
https://www.carbidedepot.com/formulas-tap-standard.htm
And here is a much more comprehensive chart:
http://www.fairburyfastener.com/tap_drill_decimal_inch.htm
Hope this helps.
Sat, Aug 8, 2015 11:36 AM
STEPHEN
If you get to the store and forgot to consult the chart, here is a easy way to figure the tap drill size for 75% thread on 60 degree V threads:
1) for inch sizes, divide 1 by the pitch and subtract from the major dia. Example, for 1/4-20 divide 1 by 20 = .050", substract from .250 = .200 and the tap drill size is a #7 drill bit at .201"
2) for metric subtract the pitch from the major diameter. Example for M6 x 1.0 subtract 1.0 from 6mm = 5mm if you do not have metric drills use the nearest size from the letter, number, or fractional drill bits.
It always works & tap drill charts are figured for 75% thread anyway.
Sun, Aug 9, 2015 9:08 AM
Willowhic
Send a private message to Willowhic
Reply to STEPHEN:
Thanks for the excellent head's up Stephen!!!
1988 JCB 1400B backhoe
1966 Cat D9 cable dozer
1966 Cat 980 wheel loader
1967 Galion 140 grader
1963 Cat D7E hydraulic dozer 47A886
196? Cat 112 grader 3U3308 (engine: 3U243)
Tue, Oct 13, 2015 5:04 AM
Willowhic
Reply to STEPHEN:
Thank you too Deas Plant! It's so convenient to have such a wealth of info available to us...sometimes I take it for granted.
Much appreciated
Tue, Oct 13, 2015 5:09 AM
D6c10K
Send a private message to D6c10K
Reply to Willowhic:
Much appreciated
If you have number size screws (ie, #6, #8 etc) and want to know the major diameter of the screw use this formula:
The # size x .013 + .060 = major diameter
#8 screw example: (8 x.013) + .06 = .164 diameter
Tue, Oct 13, 2015 7:24 AM
janmeermans
Reply to STEPHEN:
[quote="STEPHEN"]If you get to the store and forgot to consult the chart, here is a easy way to figure the tap drill size for 75% thread on 60 degree V threads:
It always works & tap drill charts are figured for 75% thread anyway.[/quote]
Stephen,
What happened to the lay it on the counter at your favorite auto parts store saying "I need a tap for bolts like these?" Then comes the hard part- "How many bolts do you want?" If I can remember the answer to the last question I am doing well. I would never remember what you have very competently laid out for us. Getting old means life has to be less complicated but thanks for posting it.
Jan
Tue, Oct 13, 2015 9:35 PM
