Power Tilt Conversion
Showing 1 to 10 of 33 results
Glum
A little while back there was some discussion on power tilt cylinders fitted to manual angle blades. Here are some pics of my conversion. Sorry about the quality from the crappy cellphone camera.
I managed to find another sectional valve bank the same as is fitted to the D4E so I was able to add another section without having to do any cobbling up. The cylinders came off of some old Komatsu D41As. Had to cut down the rod slightly and change the clevis. Modified the blade lift lever to work on two axes.
I opted to go with two cylinders and have plumbed them in series so that they have to move at the same speed rather than a parallel arrangement where the oil tends to want to work the cylinder with the least resistance first.
I'll be putting it back to work tomorrow to see how it works in the ground.
Tue, Jul 28, 2015 12:56 AM
STEPHEN
[quote="Glum"]A little while back there was some discussion on power tilt cylinders fitted to manual angle blades. Here are some pics of my conversion. Sorry about the quality from the crappy cellphone camera.
I'll be putting it back to work tomorrow to see how it works in the ground.[/quote]
So you have them hooked up like a re-phasing cylinder with out the internal by-pass?
Tue, Jul 28, 2015 4:30 AM
Reply to STEPHEN:
By plumbing them in series does the oil flow into one cylinder to extend and then exits it on to the other cylinder to retract it? do the cylinders have different ram areas for extend and retract?
Tue, Jul 28, 2015 4:39 AM
JoeG
Send a private message to JoeG
Reply to dpendzic:
I see what your asking Dpendzic, they will want to travel at different speeds given the same flow and pressure. I'm gonna bet they will work against each other to some extent but still work, I could be wrong though.
It looks nice to me Glum, I may try something similar on my D7E someday.
Tue, Jul 28, 2015 5:09 AM
STEPHEN
Reply to JoeG:
OK I'm thinking better now, I guess he has the rod ports hooked together, that way they both have the same area so as to retract/extend the same but in opposite directions.
Tue, Jul 28, 2015 6:31 AM
Reply to STEPHEN:
I'm thinking like Joe that there maybe some volume/pressure differences as the rear of the piston has more area than the front where you would subtract out the rod diameter.
Tue, Jul 28, 2015 8:29 AM
Glum
Reply to drujinin:
Stephen has it. Plumbed like the top diagram.
The angle cylinders on some of the older cat pat blades I have looked at are plumbed the same way.
Was a bit tricky purging the air and getting oil into the rod ends as they are a separate reservoir from the main system unless there is leakage on the pistons.
Tue, Jul 28, 2015 10:59 AM
Glum
Reply to Glum:
The oil displaced from the rod end of the first cylinder has to enter the rod end of the second cylinder, forcing it to move at the same speed as the first.
My reasoning was not that I need the force of two cylinders, just to create enough movement to give enough tilt without destroying the centre pivot after some use.
Tue, Jul 28, 2015 11:28 AM
Reply to Glum:
In effect, they actually operate as single acting cylinders! Force pushes them back verses Pressure pushing them back! The oil would assist the Force. A lot of the older Snowplows would have single action cylinders for left and right angle. In the case of tilt, you would need the oil in front to buffer the forces generated by the cutting edge. Nice Job! Well thought out!
Tue, Jul 28, 2015 6:37 PM
Reply to drujinin:
Hi Glum, how did you get the oil into the rod end circuit? I'm guessing you have a port at the high point of the line and used a funnel?
Also I meant to ask the group what the term is for leaning the whole blade back and forward - I'm familiar with angle and tilt but don't know what that third movement is termed?
Tue, Jul 28, 2015 7:55 PM
Glum
Neil, I connected the cylinders separately and off of the blade and worked them back and forth, leaving one fully extended and the other retracted. Then coupled them together and worked them, cracked the fittings to try release the air, then separated and repeated the process another time or two. I think you are referring to blade pitch. These angle blades don't allow for the blade to be pitched forward or backwards.
Tue, Jul 28, 2015 11:03 PM
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
