Never Saddle a Dead Horse....
Showing 1 to 10 of 36 results
seiscat
I recently viewed a post that had pictures of cable clamps securing the end of a cable to an attachment. The clamps in the photo faced opposite of each other. I have seen this mistake numerous times. The long part of the cable, the “working” or portion of the cable under load is called the “live line” and the end of the cable which is secured by cable clamps to the “live line” to form a loop is called the “dead line”. The cable clamp consists of a U-bolt with nuts and the “saddle” which is cast with an impression of the cable in it so that it tightly grips the cable. I was taught the phrase “Never Saddle a Dead Horse” to remember which way to face cable clamps.
If a cable loop is secured by two cable clamps facing opposite directions, in reality the loop is only secured by one of the clamps as the “dead line” with the saddle on it will easily slip the U-bolt along the “live line”.:doh:
Fri, Jul 24, 2015 11:41 PM
cojhl2
That is a correct phrase an I too was taught the same thing.
Sat, Jul 25, 2015 12:29 AM
STEPHEN
[quote="seiscat"]I recently viewed a post that had pictures of cable clamps securing the end of a cable to an attachment. The clamps in the photo faced opposite of each other. I have seen this mistake numerous times. The long part of the cable, the “working” or portion of the cable under load is called the “live line” and the end of the cable which is secured by cable clamps to the “live line” to form a loop is called the “dead line”. The cable clamp consists of a U-bolt with nuts and the “saddle” which is cast with an impression of the cable in it so that it tightly grips the cable. I was taught the phrase “Never Saddle a Dead Horse” to remember which way to face cable clamps.
If a cable loop is secured by two cable clamps facing opposite directions, in reality the loop is only secured by one of the clamps as the “dead line” with the saddle on it will easily slip the U-bolt along the “live line”.:doh:[/quote]
Not only that, if the U part is on the line end, it will crimp the line leading to broken wires and reduced capacity. I like the double saddle kind made by Crosby.
Sat, Jul 25, 2015 2:01 AM
egoman
Send a private message to egoman
As a certified rigger and developer of the new CSA rigging certification this is one of my pet peeves.
I grew up in a farm community where I have seen every mistake in the book as far as rigging and general safety goes.
The common argument when I bring this to their attention is that they have always done it this way so why should they listen to someone who is actually trained in this area. It was good enough for Grampa, that's all they need to know.
The BIGGEST thing in motocross
Sat, Jul 25, 2015 2:03 AM
Reply to egoman:
when i was working we had a book that had tables in it for the number of clamps needed depending on cable size and breaking strength---wish i had made some copies!
Sat, Jul 25, 2015 2:22 AM
JoeG
Send a private message to JoeG
Reply to dpendzic:
Just a quick google
and....
http://www.fdlake.com/wrclips.html
I too was taught that saying and hear it about every time I have a boom laid down and am changing blocks or reeving. I don't often re-use these clamps if I have new ones on hand. I never use them again after driving piling, they take way too much abuse, smashing the threads in most cases and once the nut is muscled over them smashed threads they aren't usable anyway.
Sat, Jul 25, 2015 2:48 AM
old-iron-habit
Same phrase I have used my entire career. It is entirely correct. And another one is when using a becket and wedge clamp for securing a cable end. The clamp should never be on the working side of the cable. An rare exception would be with a special clamp like some Grove cranes use on the becket. Only the dead end should be clamped either by making a loop and clamping to itself or by adding a short piece of cable and clamping. Folks doing any pulling or hoisting with cable and chokers should stop by their rigging supply house and pick up a rigging handbook. They are often free. You will be surprised at the number of ways they will show you how not to use a cable or choker to avoid getting hurt or worse.
Sat, Jul 25, 2015 3:03 AM
DPete
Reply to old-iron-habit:
Well, now I hafta go check my tow cable, probably did it wrong. In fact I think I braided in the loops and clamped the small ends
1962 D4C
Sat, Jul 25, 2015 4:06 AM
mrsmackpaul
Reply to DPete:
yep yep and yep try telling someone they are doing it wrong and even worse if you have to try and tell someone 20 or 30 years older than your self they can get in real mood
on lifts (elevators) and cranes in Australia we arent allowed to use bulldog clips as we call them we have to use wedges, babbitted, sockets or swages
we are only allowed to clamp the dead end and all wedges must be pinned
Paul
Sat, Jul 25, 2015 5:06 AM
cojhl2
Reply to mrsmackpaul:
Paul
I'm pretty sure Paul that here also the clamps would not be allowed on the type of loads you mentioned. But for tow cables and temp hookups we used them all the time.
Sat, Jul 25, 2015 6:50 AM
old-iron-habit
Reply to DPete:
Hey Dan,
Actually a properly braided loop will require no clamps at all for strength. If you weave the end back into the wire rope there is no place for a clamp. If you braid thru the line leaving a tail then one normally puts on one clamp to keep it tidy. Braiding end loops and fishermens splices is another almost lost art on both rope and wire rope. I still have a set of "fingers" for braiding cable somewhere from my pile driving days in Long Beach.
Roger
Sat, Jul 25, 2015 7:33 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
