Caterpillar 955h battery help
Justinc
Send a private message to Justinc
Hi all I'm just wondering what batteries I would need for my 60a 955h as when I purchased it the batteries had been taken out I also would like to convert the generator to alternator cheers😊
Fri, Jul 17, 2015 4:20 PM
gemdozer
Thank you received: 12
Some 955h had starting engine and use a 12v. battery and when the 955 is direct starting he has 24v.battery
Fri, Jul 17, 2015 5:17 PM
Justinc
Reply to gemdozer:
Hi gemdozer yes mine is 24v starter motor but I'm not sure witch battery to use as in amps or cca
Fri, Jul 17, 2015 6:54 PM
Reply to Justinc:
the 955H originally used 4-6v batteries in series.
Part # 8F2142 RPB 5S7219 Group type 2 or 2H
Google Cat batteries for info on specs.
You will have to make your own mount to run a belt drive alternator in place of the generator.
Sat, Jul 18, 2015 3:02 AM
I wonder if a 4D would fit in each battery box area? These are around a 1000 amps at 12 volts each.
Sat, Jul 18, 2015 4:09 AM
Reply to drujinin:
Two grp 31's ?
Sat, Jul 18, 2015 6:35 AM
