advise needed : D8800 cylinder head cracks
Showing 1 to 7 of 7 results
STEPHEN
OK! now my valve grinding man said that one head has been welded and one is cracked from starting inside a port and running through a seat. Casting # is 2F5317
Has anyone here welded, or had a cast iron head welded? how much did it cost? & how well did it work? any tips or tricks? I was thinking of a good pre-heating & welding with Inconel, a high nickel iron alloy (that I have on hand). Or do I just need to get a better head & save the bad one for a later day.
Sat, Jun 6, 2015 12:49 AM
mrsmackpaul
mate this is some interesting reading as far as I know welding heads can be succesful but it is a very specialized job and if the motor ever gets hot again it will open back up
http://www.acmoc.org/bb/showthread.php?22241-Repairing-Cracked-Cylinder-Heads
Paul
Sat, Jun 6, 2015 3:24 AM
Thank you received: 19
Reply to mrsmackpaul:
Paul
No reason you can't weld it up yourself using proper procedures.. I'd figure on using valve seat insert/s if the crack migrates into the valve seat area.
Sat, Jun 6, 2015 4:06 AM
STEPHEN
I do have some ceramic fiber insulation for a blanket. It would be nice to have a total junker to practice on, both with the pins and the welding. Things like this seem to have a way getting completely ruined with one wrong twitch.
Sat, Jun 6, 2015 5:32 AM
chuckb
Reply to STEPHEN:
Stephen the guy that i use has ovens to preheat and then he tries to hold the temp and cool slowly Jerry Gast used a forge and coals to heat and then weld and cover in the coals to cool slowly the guy that i use is Rays crack service in Hodgenville KY he has a web site i can get his # if u want chuck
Sat, Jun 6, 2015 6:32 AM
STEPHEN
Reply to chuckb:
Yes please Chuck, thank-you
Sat, Jun 6, 2015 7:03 AM
chriscokid
Reply to STEPHEN:
Rays Crack Repair
3710 Campbellsville Rd.
Hodgenville KY 42748
502-645-7444
Sat, Jun 6, 2015 7:17 AM
chuckb
Reply to chriscokid:
Rays Crack Repair
502-645-7444
Thanks Eric Ray is a super nice guy he has done several manifolds for me all have come back like new
Sat, Jun 6, 2015 10:03 PM
Price Tractor Pull
Price Tractor Pull
