- Thank you received: 0
Yes, removal items are similar to the D2 &D4 but:
Be sure to drain the crankcase before breaking the pony to housing seal or you will have an oil flood mess.
Also remove the magneto before lifting the pony. Rest of the stuff is fairly obvious.
Don't have to mess with the governor to get the starting engine clutch/pinion out on the D6.
cat@acmoc.org
- Chris R
- Jason N
