Good list of Dozer Manufacturers
Showing 1 to 10 of 11 results
Thank you received: 46
Thu, Apr 23, 2015 1:26 AM
7upuller
Hey OldMagnet,
I got kicked out a couple of times, but the third time I got the page. Wow what a great collection of Dozer Blades. The Baker 9X cracked me up. Imagine the dozer blade hooked up solid and raise and lower the whole tractor... Wow great stuff. I even figured out where Romekg got his handle from...lol
Thu, Apr 23, 2015 1:55 AM
mog5858
Reply to 7upuller:
Hey OldMagnet,
that's a nice page with lost of info thanks. was a good little read cus there where lost of pics lol
Thu, Apr 23, 2015 4:05 AM
Reply to mog5858:
lol ya My dads name was Ken n mines Gary, we have Rome plows and disks so the name fit.
Thu, Apr 23, 2015 7:27 AM
8C 361
Thank you received: 12
I like the GarWood blade on the HD5 with the Rams lifting off the hard nose. It does not give the date but I think they built those in the early '50's. Much more advanced than the 4S and 4A blade that Cat built at the time. I don't think Cat made blades like that until the '60's.
Thu, Apr 23, 2015 9:44 AM
chriscokid
Reply to 8C 361:
Roger A. Has done a good job putting that info online. He is a fine person and has done a great deal to document the "classics"
Thu, Apr 23, 2015 10:09 AM
Inter674
Reply to chriscokid:
is there any particular trick to viewing this web page?
Everytime I try it, the page freezes up and I have to quit out of it😞
Thu, Apr 23, 2015 11:54 AM
Reply to Inter674:
I've not had any trouble viewing. First couple times there was an ad that I had to get out of but don't see that ad any more.
Thu, Apr 23, 2015 11:59 AM
Inter674
I fiddled with the 'Tools - Compatibility' setting and it fianlly loaded up.
Nice web page!
Thu, Apr 23, 2015 12:31 PM
Thank you received: 106
Reply to Inter674:
Nice web page!
Hi, 8C 361.
There is a VERY good reason that the D2s and D4s didn't have the hardnose blade lift arrangement on the early models - 'cos they didn't have main frames to support the engine, radiator AND the weight of the blade out there. If you look at the D2s and the D4s up to the D4C, you may notice that the engine block IS the entire support for both engine and radiator ahead of the equaliser spring. Can you imagine what might happen if you tried to hang a blade lift on that?
The D4s were given a main frame and a hardnose with the D4D.
Cat were NOT the only ones in this boat by a LONG chalk. IH was another one and they had this design with their equivalents of the D6 and the D7, the TD14 and TD18 respectively, as well. It was not until IH introduced the TD24 in 1947 that they had anything with a hardnose blade lift.
Even with the bigger Cat models back in the early days, LaPlante-Choate for one made blade lifts mounted on the track frames for D7s and D8s. Prior to the advent of OEM hardnoses on Cat machines, a frame needed to be added off the main frame around and above the radiator to carry the blade lift, as with the LeTourneau headache bar arrangement.
Hi, Inter 674.
If you get that pop-up window about the blog domain name registration being out of date, look at the top right corner of that window for an 'X' and the word, 'Dismiss'. Click there and that should disappear leaving you unfettered access to the goodies behind. Happy browsing.
Hi, Glen.
Here is a link to a Youtube video clip of the HD9X with the Baker experimental blade:
https://www.youtube.com/watch?v=EuswWf1kp7E
Sun, Apr 26, 2015 6:48 AM
Old 3T lover
Hi, 8C 361.
Hi, Inter 674.
Hi, Glen.
Hanging a blade on the nose of a dozer is/was, to say the least, stressful....I've seen a 2U D8 and a 13A D8 with the engine and nose broken off right through the transmission case....both had hydraulic blades if that made any difference.
While in high school I bought a IH TD9 with a Heil cable blade hung off the nose. The IH's of that time period had cast iron mainframes. The motor and nose didn't fall off but I did break out the side of the mainframe. I welded it back together a couple of times but there really isn't any way to fix those kinds of breaks and still hang a blade off the nose alone.
Sun, Apr 26, 2015 7:23 AM
