Caterpillar D6C 76A Undercarriage Parts
Showing 1 to 10 of 10 results
D2 Cody
Send a private message to D2 Cody
Hi all,
Looking for a good place to purchase good and reasonable priced,either used or new undercarriage components for my D6C. I priced a complete new undercarriage here in Nebraska at a shop and parts alone were a little over 12,000.00.If I could find good used parts at 80% 0r better that may be another option so if anyone knows of a place please let me know.Thankyou in advance.Cody👋
Cat D6C 76A2045
Cat No. 12 8T15616
Caterpillar-Dodge-Lincoln-Stihl-Echo-Craftsman
Fri, Mar 13, 2015 2:03 AM
Casey Root
Hi Cody
As popular as the D6C/D is, you shouldn't have much trouble finding an older machine that has lost an engine or another part of the drive train and has good UC. I got lucky and found some after market SALT chains with 20 in pads (90%) and a full set of 10, double flange (80%) Cat rollers all for $3,400.00. Nose around and take your time if you have it. You'll find what you need. I'll bet you will do it in less than 6 months.
Casey
Fri, Mar 13, 2015 4:30 AM
D2 Cody
Reply to Casey Root:
Hi Cody
Casey
Hi guys,
Well found a used undercarriage (the whole track frames) including rails,top and bottom rollers idlers,pads,drive sprockets,and etc.the guy wants 4500.00 for everthing.The parts are about 80 percent or better.Looking for opinions on the price,does this seem decent or to high?
Cat D6C 76A2045
Cat No. 12 8T15616
Thu, May 28, 2015 11:03 AM
Reply to D2 Cody:
Hi guys,
Usually you figure good used is worth at least 1/2 the price of new.
Assuming you don't have to ship it cross country, sounds like a good deal to me.
Thu, May 28, 2015 12:21 PM
rmyram
that's a really decent price for all the bits you mentioned, head down to your local dealer and find out what all those parts cost and you'll be looking near 20 grand. id be snapping that up in a heartbeat.
Fri, May 29, 2015 8:35 PM
Casey Root
Reply to rmyram:
Congratulations. Sounds like your LOTTO numbers just hit. You are getting a lot more than I got for only $1,100.00 more. And it looks like you got it done in about 75 days.
Good on you!
Fri, May 29, 2015 8:56 PM
mrsmackpaul
Good on you!
Im no expert but if the gear is as good as you are saying Id grab it before he changes his mind to find good walking gear at the right price is always going to be a challange
Paul
Sat, May 30, 2015 3:11 AM
D6c10K
Send a private message to D6c10K
Reply to D2 Cody:
Hi guys,
[quote="D2 Cody"]Hi guys,
Well found a used undercarriage (the whole track frames) including rails,top and bottom rollers idlers,pads,drive sprockets,and etc.the guy wants 4500.00 for everthing.The parts are about 80 percent or better.Looking for opinions on the price,does this seem decent or to high?[/quote]
I think you should pass on it......Oh, where did you say the parts were located? 😖mile:
Seriously, that sounds like a deal. My undercarriage is getting pretty well gone, and no more hours than I use it, it would make a lot more sense to buy good used. Are 76A track frames the same as 10K?....For the right price I might consider changing mine out as they're not in the best of shape.
Sat, May 30, 2015 4:25 AM
Reply to D6c10K:
Track frames for the 76A & 10K are the same until 10K3553 when there were some changes done to the diagonal brace shape but I believe they will still fit.
Sat, May 30, 2015 9:26 AM
seiscat
Early D6C tractor bottom rollers used smaller diameter attaching bolts. If 15/16" socket fits = small bolt rollers, if 1and1/8" socket fits = large bolt rollers. I don't know know what S/N the larger bolt rollers were introduced, perhaps Old Magnet can help with this.
This will not matter if you are swapping the entire roller frames, but if the new-to-you roller frames are the later model large bolt variety you will need to order the large bolt rollers when the rollers need to be replaced.
Sat, May 30, 2015 10:17 PM
Reply to seiscat:
Track roller bolts did change at 10K1-up.
Sun, May 31, 2015 6:52 AM
| Hartley - South Australia
Newby Hall Tractor Fest
