D4 Series Identification
Showing 1 to 10 of 28 results
bryani289swmi
Send a private message to bryani289swmi
I might take a ride and look at this machine in the future, looking for some help in identifying the series/year. Any help is appreciated. Thanks.
Bryan
Fri, Feb 27, 2015 7:39 AM
Looks like a 7J series 44" gauge 1939-1942 or a 2T series 1943-1945 year.
Fri, Feb 27, 2015 8:06 AM
rjh-md
Could be a 5T from1945 to 1947 also 7J , 2T, 5T look simular check for the serial number plate on left side rear of engine block and rear of main case ,left side . Don't know manufactured that blade looks like a light weight design
Fri, Feb 27, 2015 8:51 AM
Reply to rjh-md:
That is a LaPlante-Choate Trailblazer!
Don't worry, there is a lot of iron in that blade!
There is lots of grouser on those pads, Idler looks pretty far back in the one angled photo!
Fri, Feb 27, 2015 8:59 AM
Thank you received: 42
Reply to drujinin:
Hi, Rjh-md.
If that is a 'LIGHT' blade, I BET you'd just LOVE a real heavy one on that same tractor. Have a look at the C-frame. I seriously doubt that many broke up under the strain of the tractor and hard work.
The lift arrangement looks a bit light at first glance but I'd suggest you not that fool you too much either.
Fri, Feb 27, 2015 10:14 AM
Hi, Rjh-md.
I thought the 5T's had the larger track frame and final bearing mount?
Fri, Feb 27, 2015 10:31 AM
Thank you received: 19
That would be prior to 2T8270 when they changed to the large final drive hub. Most likely a 7J or 2T model.
Fri, Feb 27, 2015 10:58 AM
catsilver
A later 7J or early to mid range 2T. It has the governor on the back of the fuel injection pump.
Fri, Feb 27, 2015 2:20 PM
rjh-md
Reply to catsilver:
Deas Plant I know the lower part of the blade looks strong ,but look at the thickness of the lever arms attached to the lift cylinders ! looks like 3/4 0r inch plate welded to the blade arms .I could forsee a lot of twisting action in the plate and welds .Be interested to see if the welds have been rewelded on both sides before . Cat blades have the links that allow for the side twisting action .
Its probably a 7J tractor I mentioned 5 T as it shows up in the serial # book with the 7J shown ,and all 3 serial # tractors 2T,5t AND 7J are close in appearance
Only one way to make sure ! get the serial 3 OFF THE TAGES !
Fri, Feb 27, 2015 8:25 PM
rjh-md
I owned a 5J D2 that had a LaPlane Choate angle blade on it .I thought it was a very nice blade ,and it graded well .Only problem was it had a rear mounted hydraulic pump ,and when the master clutch was released ,there was no blade hydraulics ,hard to get used too!
The blade on that D4 dosen't look anything like the D2 blade
The tractor looks very nice ,may have been a farm Cat with the rear mounted PTO
Be interested to see what the hour meter reads
Maybe the pictures are deceiving on the blade .You guys like it more than I do !
Sat, Feb 28, 2015 8:18 AM
MarkMcCune
Send a private message to MarkMcCune
I have the same blade on mine and it is well built . I have a 2t #2325 and its a 1943. I posted some pictures of mine . It is army green still trying to learn about possible military use > it has WSP stamped after serial number
Sun, Mar 1, 2015 5:02 AM
