Reply to R4pat:
Thanks SJ
I'm not in a real hurry, I will probably sent them up there if I don't find any other alternatives
Pat
Hi team,
just back on deck after touring our mighty Snowy Mountains Hydro/electric Scheme, and Ski Fields in the surrounding areas--- it is summer here and the snow is all but completely gone, just a few patches left in sheltered areas.
We stayed at Jindabyne on the side of one of the schemes lakes, we encountered a week of 30-33degC temps.--a heat wave for the locals--average summer max temps are in the 20-23degC range--global warming ??? we drove home in temps of 40-42degC temps through Gippsland yesterday!!!!!
The "Vee" grouve cut outs on the side of the pump plunger working area is to give a steadier (non hunting) low idle. These pumps cannot be mixed with others without the Vee as it requires a greater position of the rack to give an idle volume of fuel. Leakage of injection fuel occurs across the Vee and affords a larger movement of the rack to change the volume of fuel injected and this in turn steadies out the Low Idle hunting.
IF the two types of pumps are mixed the Vee grouved units will tend to display a miss at low idle due to the lower volume of fuel delivered per unit of rack setting as compared to a non Vee grouved plungered pump.
This subject was covered recently either here or on the ACME BB.
The pump plunger and barrels are selective fitted at the factory for best fit, so it is possible to mix and match parts if they are in the tolerance range of each of the plungers and barells. In a production run there will always be a plus and minus variation of the target dimension for the particular component and these parts are often identified in say car pistons and bores as A or B,C,D etc size for mixing and matching for best fit IE they can use std oversized pistons to best match an oversized bored cylinder---here we are talking in the upto plus or minus one thou range not 10 or 20 thou. Although during WW2 I believe many makers used std over/under size components in their engines so as to cut wastage.
OM, sorry do not have 7J P/B, have D6 4R1-up P/B and it also shows the 2A3895 Pump Ass only (form 8885 / March 1945) as does my TM5-3100 War Dept D6 maint&parts catalogue for D6--4R680-up and 5R903-up. Also 9K grader.
Hope this helps,
