pre compression chambers D7 3T
Showing 1 to 10 of 40 results
mrsmackpaul
I have to change the pre compression chambers on my old 7 wondering if anyone knows what the tool number is used to remove the nut on the injectors and also the tool number for removing the pre compression chamber
any help appreciated
Paul
Thu, Jan 29, 2015 7:53 AM
Old 3T lover
Can't remember the size but one can be made quickly from a nut and bolt.
I put 2 nuts on a bolt and spot welded them together and then to the bolt. Drop it in pre cup and use a large pull handle.
Thu, Jan 29, 2015 9:24 AM
leon
Send a private message to leon
Don't know tool no.[have one in shop with no. stamped on head will send info tomorrow,for pre-combustion chamber] will part with it if you are interested. e-mail is open.
Leon
Thu, Jan 29, 2015 9:34 AM
Hi Paul,
scan below should help. It is tool # 1F0479--modified as per Service Magazine, Nov 30 1954.
Tool for injector rem/refit is #7B4973--from the Parts Book.
Hope this helps,
Thu, Jan 29, 2015 9:39 AM
Jack
Reply to edb:
Hi Paul,
Hope this helps,
I think you are referring also to the union nut that holds the injector valve into the head assm?
i can't get the number without digging into my old books in the shop or dig out the special tools, but it's a large, bell-ended deep socket with one side milled away for clearance around the injection tube. They cost a lot. Those nuts get stuck real bad some times. After I broke my wrench and welded it back together, I welded a big nut onto the top so I could use a MANUAL IMPACT WRENCH on it. Since that modification I haven't split it again nor have I been stopped by a rusty injector nut.
Thu, Jan 29, 2015 11:44 AM
mrsmackpaul
Reply to Jack:
thanks for the replies your onto it Jack thats the tool I am chasing Lance Jones said he will send me his up in the mail to get me out of trouble thank you Lance
I spent the last day making one up in the shed I reckon I did a real good job I got the two nuts un done on the back head but it just not tough enough for what I need with a tight nut and started to spread anyway hopefully when the proper thing turns up I will be cooking with gas
[attachment=27310]IMG_0197_zpsgrtiqqnd.jpg[/attachment]
[attachment=27312]IMG_0198_zpslosjgxug.jpg[/attachment]
who can tell whats missing free beer from your own fridge the correct answer sorry Swishy stole your line mate
[attachment=27311]IMG_0199_zpsvmqyzixx.jpg[/attachment]
looks she has had a sleep before I owned her
[attachment=27313]IMG_0201_zps7i92pppc.jpg[/attachment]
seeyas
Paul
Thu, Jan 29, 2015 2:15 PM
Andrew
Reply to mrsmackpaul:
seeyas
Paul
G,day Paul.
Is this what ya want.
A...K...
Thu, Jan 29, 2015 4:35 PM
mrsmackpaul
Reply to Andrew:
G,day Paul.
A...K...
yes mate thats the one I will wait and see if the one Lance has is the right one and if so I will order one from Florin parts in the US
Paul
Thu, Jan 29, 2015 6:41 PM
Lance Jones
Paul
Hi Paul , That's the one as Andrew's Pic's Showed , mine doesn't have that pretty paint on it , still in its Working Clothes !! Be in mail Tomorrow LJ
Thu, Jan 29, 2015 10:48 PM
Reply to Lance Jones:
Hi Paul,
missing is the auxiliary spring set up.
You run the risk of winding the tractor up and over on itself to cause a severe/fatal outcome.
Fri, Jan 30, 2015 6:52 AM
Jack
Reply to edb:
Hi Paul,
Not a bad production on the socket considering no pattern to work from. The Cat tool is a 12-point and they cut away just enough of the side to allow 1/12th of a turn and then you reset it on the nut. The broached 12point is only about 1/2 inch deep so they could hold maximum strength as far down as possible before they cut out the side. All that, and they still break occasionally.
Give that hand impact wrench some serious consideration. It's amazing what they can break loose. They used to be in the Cat ONE SAFE SOURCE sales flyers. (Anything old enough to have that type injector is old enough to be really rusty...)
Fri, Jan 30, 2015 10:24 AM
