Caterpillar 10- powertake-off
Showing 1 to 10 of 12 results
carole walker
Send a private message to carole walker
I purchased a 10 with a power takeoff not installed. The pt converts the drive shaft to a pulley drive and turns power 90 digrees. Attempted
to install but bolts and frame do not line up. The books I have do show pt. Does any one have drawings or anyone have a similar pt
Gene
Thu, Dec 25, 2014 5:40 AM
rturn3060
Send a private message to rturn3060
You probably have a PT off of a PV15 or 22
Thu, Dec 25, 2014 5:50 AM
Thank you received: 19
Reply to rturn3060:
If your talking about the flange mounting to the tractor the pattern should look like this.
Thu, Dec 25, 2014 6:07 AM
carole walker
Thanks for help. The p-t I have connects to p-t on Ten which is the same as in your picture. It turns power 90 dia and has a flat pulley. The unit has a square metal box with 4 studs to connect to case. The bolt pattern is larger than on Ten or on 22. I have tried to add pictures from photo gallery to this page. I am lacking in computer skills.
Thanks again to both of you for help.
Gene
Fri, Dec 26, 2014 4:41 AM
Reply to carole walker:
Gene
This is the arrangement for the Ten....
Fri, Dec 26, 2014 6:58 AM
carole walker
[attachment=26687]100_0372 - Copy.jpg[/attachment][attachment=26686]100_0371 - Copy.jpg[/attachment][attachment=26685]100_0369 - Copy.jpg[/attachment]
after trial and error loaded pictures on page
The above pictures of P-T pattern of holes in P-T do not fit bolt holes around shaft on Ten
Thanks for help
Gene
Fri, Dec 26, 2014 9:49 PM
brewzer
Thanks for help
Gene
You will never get that to work because it is not the correct one. It looks like a PTO off a 9N ford or similar. You do not have the correct part. - Wally
Fri, Dec 26, 2014 10:02 PM
JoeWestfall
Send a private message to JoeWestfall
Reply to brewzer:
I have a stationary drive on my CAT TEN that does not have
a shifter lever on it. My serial # PT322.
What kind is this?
Joe Westfall
Sat, Dec 27, 2014 11:09 PM
Thank you received: 23
Reply to JoeWestfall:
What kind is this?
Joe Westfall
Joe, take photos from different angles and someone will be able to identify it for you - see if you can include some casting numbers.
Sun, Dec 28, 2014 3:43 AM
carole walker
Joe
I found a cast number on side of case A-PT-748 . This is not CAT number does anyone have any information on this P-T.
Joe does your Ten have a lever under seat for P-T . Could you sent pictures.
Gene
Gene
Sun, Dec 28, 2014 6:23 AM
brewzer
Joe
Gene
Gene
Early on Cat made the 10 PTO without a shift handle. When the tractor was running the PTO was running. I have one also. -
Wally
Sun, Dec 28, 2014 12:15 PM
