Rome disking pics
Rome disking pics
Showing 1 to 10 of 97 results
cab
Send a private message to cab
Here are some photos taken last week of my D7 47A pulling a rome disk in the brush. I was very happy with the results. Clutch needs tightening down some more as it was slipping at times in 2nd gear, but did not in 1st. I adjusted it once recently but guess didn't rotate the ring enough. Also the rest of my scrapers arrived and I got them installed after pics were taken.
The pasture had been cleared 30+ years ago into strips. I am disking the same strips that have regrowth, leaving the bigger mesquites.
Wed, Dec 17, 2014 11:22 AM
Tim Matthews
Send a private message to Tim Matthews
I like your disc! I have been using my rake plucking those rascals getting a pile going and for the most part pulling the small ones . But you know mesquite pull one and a dozen come back. I have my 3t in Cotulla . Tim
Wed, Dec 17, 2014 11:43 AM
cab
Reply to Tim Matthews:
Tim-
Mine is in Zavala County now, but lives in Frio County. Just a few miles north of you! Do you have a pull behind rake or a stacking blade? I sure would like to find a good heavy built angle stacking blade with C frame for my tractor.
Wed, Dec 17, 2014 11:58 AM
Raeme
Send a private message to Raeme
Reply to cab:
Tim-
Look how deep that is cutting in!! Fantastic thanks for sharing. Cheers
Wed, Dec 17, 2014 3:59 PM
Reply to Raeme:
Cab I noticed where you have the back gang bolted on its all the way to one side, I have mine set with two open bolt holes on each side of the top frame. This makes the disks cut in the same cut as the front when opened up. It looks as though the back gang is to far to the right.
Fri, Dec 19, 2014 7:54 AM
Here is a pic of the back gang on mine.
Fri, Dec 19, 2014 7:59 AM
I It looks like the front gang is angled quit a bit I guess it depends on where you have the hitch and tounge set too.
Fri, Dec 19, 2014 8:04 AM
Ya Pete, that's what I was thinking too.
Gary
Fri, Dec 19, 2014 8:06 AM
Gary
Ya, In the first pic you can see the front gang has too much angle too it, need to reset the front hitch so the front and rear gang are about the same angle when in the disking position.
Fri, Dec 19, 2014 8:09 AM
Keep talking because I'm learning!
Is there a way to tell how to set the first gang in relation to the hitch?
Then I assume the second set should ride in between the front coulters?
Fri, Dec 19, 2014 8:17 AM
Reply to drujinin:
The triangle bracket on the hitch can be set to center the disk with the tractor when disking. The drawbar swing setting adjusts the pitch or draft of the front gang when disking, I think that's what cab has to adjust (the drawbar swing).
Fri, Dec 19, 2014 8:59 AM
