Wanted to borrow hex tool for D2 J-series combustion chambers
Showing 1 to 10 of 19 results
Thank you received: 20
Team,
can someone lend me this piece (or let me know if there's an easy way to procure it) - I need the hex tool to remove the pre combustion chambers from the J-series cylinder head. The machinist says we need to plane the head so we need to pull the chambers.
I'll pay all shipping etc.
Sat, Nov 29, 2014 9:58 AM
Lance Jones
Hi Neil I have one here in Ozz , but postage Would Kill You . Get a Hex socket the Right Size and Cut a piece out the Side so it Fits nice may need to Cut Socket and Lengthen it ,just can't remember .LJ
Sat, Nov 29, 2014 10:12 AM
gauntjoh
Librarian
Reply to Lance Jones:
Hi Lance,
Neil is looking for the tool to extract the precombustion chambers and I think what you refer to is making a tool to remove the injectors...
Neil, I'm afraid I can't help you, if I had one of these, the postage from the UK would be very expensive also.
Best Regards, John
Sat, Nov 29, 2014 7:37 PM
Reply to gauntjoh:
Hi Lance,
Best Regards, John
Thought we've been through this before....Just make one up using a 7/8" grade 8 bolt (1-5/16" head) with a few stacked nuts welded together.
Sun, Nov 30, 2014 12:40 AM
Lance Jones
Reply to gauntjoh:
Hi Lance,
Best Regards, John
John You are right on there , I must have had a Seniors moment there ,I borrowed a Tool to do one some time ago . A multi splined Bolt Type Tool , But I can't recall Tool Number , sure someone will Chime in with That No. Should still be available from Cat . You will need to Replace the O-ring seal which will be available from Cat . LJ
Sun, Nov 30, 2014 12:46 AM
That's what I'm going to do but the reason I asked is I'd prefer to use the tool if it was easily available. Have ordered a 2 1/2" long coupling nut and a grade 8 capscrew. I think the nut may even be long enough by itself because with the lower edge even with the lower edge of the hex inside the chamber, the nut will protrude 1", which "should" be enough for a socket and rattle gun
Sun, Nov 30, 2014 1:15 AM
LJ,
Wrong again, takes this tool for the 3-3/4" bore D2.
Sun, Nov 30, 2014 1:16 AM
$45.00 for a grade 8 coupling nut seems a little rich to me.
Sun, Nov 30, 2014 1:30 AM
Such is life...
Sun, Nov 30, 2014 11:38 AM
Texasbest
Send a private message to Texasbest
Such is life...
[attachment=26190]image.jpg[/attachment][attachment=26188]image.jpg[/attachment][attachment=26189]image.jpg[/attachment]
Here is the tool I made. I ended up having to pull the head as the injectors & precups were TIGHT in there! Heads on the ground, still have 1 injector & 2 precups in it. I ended up rounding the edge of the nut on the tool and the internal teeth inside of # 2 precup before pulling head. Motor was pressurizing the cooling system. #2 & 3 holes look like this. I'm afraid this head may be cracked.
Mon, Dec 1, 2014 10:25 AM
Reply to Texasbest:
I'm going to have the machinist put the chambers through a heat/cool cycle just to loosen things up and then spray some Kroil on it and scrape any thread that protrudes as this head is gold - I've ordered new guides, seats, valves, springs, keepers, I'll check the chambers once they're out to see if I want to swap them out too - probably will, then the head will be like new
Tue, Dec 2, 2014 8:58 AM
Newby Hall Tractor Fest
