Big fifteen track bolts
Showing 1 to 10 of 15 results
tailseat15
Send a private message to tailseat15
I'm working on getting a set of tracks put together for the Orchard Fifteen and am having my pin and bushing donor tracks disassembled right now. (thanks for the referrals from when I asked earlier)
What I am lacking right now is a complete set of track bolts and nuts. Now what I'm looking for is the early Fifteen style of nut and bolt, with the nut that is 3/8" tall. P/n 2b5483 & 2b5484. I have ordered a sample one each from Cat, but won't have them till Monday. I also checked mcmaster Carr and two local hardware suppliers, and what I have some up with is a grade 8 7/16" bolt that has the right length without threads, and I can them trim it to length ( the correct length bolts are threaded all the way, and I don't think I want the threaded portion in the rails and pads).
For the nuts, they can get me the exact nut, but it's the taller style like the twenty twos and d2's. It uses a 5/8" width/wrench (all the current regular nuts use a larger 11/16" wrench). I can trim these down also, but my question is, do any of you know where I can get the correct "short" nut, with the narrow 5/8" width? I know I haven't gotten my samples from Cat yet, so I'm hoping but I think they will be the later style also.
I am just trying to find the hardware that's close, without quite so much hand-labor. I was able to save about 1/4 of my original nuts, but that's not getting me too close.
Sun, Oct 19, 2014 8:43 AM
sr4440
Send a private message to sr4440
Hi Steve,
Are Twenty Two nuts and bolts the same?
The parts cat is going to the scrapper in Dec. You're welcome to those if you want them.
Scott
Sun, Oct 19, 2014 6:20 PM
tailseat15
Reply to sr4440:
Hi Steve,
Scott
Thanks scott. Actually the 22 nuts on all mine are the taller style, but I've been meaning to call you anyways. I need two more good 10" wide pads to finish this set, and was wondering if that machine had 10" pads. If I remember, one side rail was newer than the other. I'll call you later today.
Sun, Oct 19, 2014 9:19 PM
tailseat15
Reply to tailseat15:
[attachment=25648]20141019_075157.jpg[/attachment][attachment=25649]20141019_075124.jpg[/attachment]
Ok, pics to help. Left bolt is a modern replacement, with taller rounded head, slightly longer and square nut. Second from left is original bolt, washer and nut that I'm trying to duplicate. Next is the 1-1/4" new grade 8. Note it's threaded all the way, and the new nut which is wider and takes a 11/16" wrench. Then the bolt on the right is the longer grade 8 bolt I cut to length, and the new coupling style nut which am thinking about trimming to be shorter, and it has the correct narrower 5/8" width. The far right bolt is one that i cut out with a torch, since the head is too worn down to turn with a socket.
The grouser pad is what I was talking about needing 2 more as close as possible to it. My donor tractor had the old cut one link out treatment. That's why I'm short one pad on each side.
Sun, Oct 19, 2014 10:43 PM
truckun95
Send a private message to truckun95
You could try Fastenal if they are in your area it might be possible they may have a supplier that makes similar nuts or bolts. I have gotten many odd ball and different fasteners in the past from them for several projects. Other than that a few years back I remember working with both the tall and short bolts and the square and hex nuts as I worked at the local Cat dealership.
Mon, Oct 20, 2014 12:41 AM
tailseat15
Reply to truckun95:
Thanks, I tried fastenall and struck out there, but I agree they are great for lots of stuff. I am just being difficult trying to match the early parts as much as possible.
Mon, Oct 20, 2014 12:53 AM
tailseat15
Update: I was able to get some time today, and harvested 66 more nuts from parts tractor #2! I have some more to get from it, but ran out of time! So up to 132, I have enough for one side at least now. 👍
This tractor had bolts that were in better shape, they weren't quite as worn down so bad. So I was able to get a socket to turn more of them.
Mon, Oct 20, 2014 7:09 AM
tailseat15
Update: I think I lucked out, found a very close brand new 7/16" nut, with the correct width and height. So now, I have found both the correct size shorter and taller nut, for either the fifteen or twenty two. Without having to do any cutting!:dance:
Now for the bolts, the closest I have gotten is a 7/16" X 2" grade 8, and cut to length so it has the matching portion not threaded that is in the pads and rails, like the originals. I made a simple jig to cut them to length.
I received my bolts from Cat. They are the black colored ones. I decided to not use them just because they have the larger size 11/16" hex for both the bolt and nut, and I'm trying to match the old ones as close as I can. It doesn't hurt that the grade 8's are quite a bit less expensive, also.
I don't think it would be a problem using a full threaded bolt with regards to the threads being in the rails, but has anybody else seen the threads squash down and loosen is a track application? I really don't think these little tractors would be nearly as demanding as a larger tractor would be.
anyways, enough rambling. Here's a couple pics of what I found, in case anyone is interested.
[attachment=25775]20141025_214219.jpg[/attachment][attachment=25776]20141025_214347.jpg[/attachment]
And my donor rails that I am having disassembled for the pins and bushings should be done soon. I am still working on taking the pads I want to use off the tractor they are on right now. Sure would be easier if these old bolts I am removing weren't so rusted and worn away! But after cutting several hundred off, I'm finding it's probably equal to or faster to just torch them off than it is to unbolt them, considering the time it takes cleaning the rust and dirt off with a chisel to get a good bite with the socket.
Sun, Oct 26, 2014 12:39 PM
sr4440
Hi Steve,
The Twenty Two pads are 10 inches.
Sun, Oct 26, 2014 5:26 PM
josh
Reply to sr4440:
Hi Steve,
Using a full threaded bolt or any bolt that does not have the proper track bolt shoulder will come loose right away, and damage things. If you were going to use it for a static display, that will work, but even running it in shows will be enough to do damage with the wrong bolts.
Sun, Oct 26, 2014 7:49 PM
tailseat15
Reply to josh:
I used my caliper to measure the diameter right below the head, on the non-threaded part. All three bolts (original, new grade 8, and new Cat replacement) have the same diameter of around .430- .432". Does that mean that these should all work right?
Sun, Oct 26, 2014 10:39 PM
Newby Hall Tractor Fest
