Horizontal Pony Starter Rope
Showing 1 to 9 of 9 results
went to The Dealer yesterday and got them to look up the above rope lengths by Part Number on their NPR.
From a 1966 Cat Technical Partsgram I have it says :- 1/4" polypropylene sash cord with a minimum Tensile Strength of 250 lbs.
My original D4 one here appears to be 1/4" braided cotton and is 6 feet long.
By the Cat Numerical Parts Record at The Dealer I was given the following lengths :-
D2 & D4 (3B3808 rope) is given as 2 Metres = approx. 6'6"
D6 (8B9724) is given as 3 Metres = approx. 10'
Hope this helps.
Thu, Sep 25, 2014 9:32 AM
Sasquatch
Handy specs there, edb. Would be great info to archive here.
Those specs sparked my curiousity so I dug out the 3B3808 pony starter rope from my NOS D4 tool kit and compared it to that info. It was spot on, the rope measured 6' 5" from the base of the wooden handle to the knot on the end, and I suspect that if the knot was tightened up a bit more the extra inch difference would be easily had. Also to note, the wooden handle on the end is right on 4" long and has a slight taper toward each end. The rope looks and feels just like what my parents always called "clothesline rope" that I remember them buying in 100 foot coils and stringing up to dry clothes on outside. Could be the same stuff.
[img]http://i802.photobucket.com/albums/yy310/TRNelson/photo1_zpsc14423a9.jpg[/img]
[img]http://i802.photobucket.com/albums/yy310/TRNelson/photo10_zps67d74aec.jpg[/img]
Thu, Sep 25, 2014 10:29 AM
Thank you received: 23
Reply to Sasquatch:
Toby, that definitely looks like the old sash cord used in double-hung windows back in the day when they had cast-iron weights. Now I know what to go get from the hardware store - thanks for posting and Ed for the info!
Thu, Sep 25, 2014 10:33 AM
seeing Sasquatch's starter rope with a normal land lubbers Overhand Knot that can slip at anytime with possible hurtful results.
I suggest using a Figure Of Eight Knot for Safety Reasons--less liable to slip.
Scan below shows how to tie a Figure Of Eight Knot.
Thu, Sep 25, 2014 11:08 AM
ronm
Reply to edb:
Thanks, Eddie-
I was just looking at the parts book & trying to guess the length of that rope for the D2...hard to tell from the pic...
I wonder if the handle is still available from Cat...rope is no problem at the hardware store.
Sat, Sep 27, 2014 8:54 AM
Thank you received: 19
Reply to ronm:
Thanks, Eddie-
Piece of 1" dia. wood dowel works fine.
Sat, Sep 27, 2014 9:01 AM
ronm
Kinda figured that-
Sat, Sep 27, 2014 9:42 AM
Dozerman51
Reply to ronm:
Kinda figured that-
Interesting: I have a Cat Parts catalogue for 3J tractors from 3J#1 to 5000, form 6700. On page 221, it lists the rope and handle as Part#3B3809.
Joe Giraud
40' Cat D2/3J#4103
41 Dodge WC-12 Military 4x4 Pick-Up
Sat, Sep 27, 2014 10:39 AM
ronm
Reply to Dozerman51:
Joe Giraud
40' Cat D2/3J#4103
My book lists the handle as 3B3809 & the rope as 3B3808.
Sat, Sep 27, 2014 8:49 PM
cojhl2
Reply to ronm:
Starter ropes are special, not clothesline or other cotton rope.
There is a special cord that does not stretch under load.
I find it at Farm supply Stores. (We use it on the small engines of our wheel lines.)
My 0.015
Sat, Sep 27, 2014 11:01 PM
