Alternator problem
Alternator problem
Thank you received: 6
17 years 1 month ago #10282
by ol Grump
Seems I saw something about alternators here a while back and thought I'd ask a question. Is direction of rotation critical to proper operation? I took mine off and had it checked. .results were that it worked properly on the bench but when I put it back on, it shows zero charge rate. I thought it might be the ammeter and changed to a known good one but still get zero charge.
According to the place I took it, one wire on the back goes to the battery, one wire at the top (red) goes to the terminal on the back and the other wire (white) goes to a switch. The white wire is the one that's supposed to activate it.
This is on a D315 engine in a D4 7U. Even at high idle it doesn't show that it's charging.
Thanks,
Paul
17 years 1 month ago #10285
by AJ.
Alternators will charge rotating in either direction,the heavy cable going on to the + or BAT terminal should be hot all the time and the light wire that goes from it to terminal 2 when the main switch is on,if your exciting wire is going through an oil pressure switch you need to check it with the main switch on and the engine stopped to see if its hot at terminal 1,if not check to see if its hot going into the switch,if so bad switch,if not check wire power source,to test the charging momentarily put power to terminal 1 and check to see if it showing a charge,if it is sort out the exciting circuit,if not are the light wires in the right place? on the back of the unit.
AJ
Thank you received: 10
17 years 1 month ago #10286
by ccjersey
Quick check on the alternator, does it magnetize the back of the alternator over the rear bearing? If it does, it's exciting and you probably have a bad connection somewhere. You should also check the voltage output at the stud on the back with it running. Also check for battery voltage at the output stud when the engine is stopped (unless you have a battery disconnect on the system) No voltage at the output stud means no circuit to the battery so no charge on the ammeter.
I don't think the direction of rotation makes a difference. There have been some arguments about the effectiveness of the fan if you turn the thing backwards, but that's another issue. "normal" rotation is clockwise facing the drive end/counter-clockwise facing the output end, but again I don't think it matters.......It's an alternator after all.
Is yours a Delco? Direct drive conversion? Or a belt drive from?????
On the Delco 10SI which is used for many of these, the regulator terminal from the switch is the one on the left looking at the rear of the alternator (output stud is to the left and regulator plug is at the top) The heavy wire on the right, going into the same plug, is commonly attached to the output stud by a short jumper in a conversion where there isn't a wire in the harness to attach it to.
Most common problem is not turning fast enough, but if your regulator wire from the switch is hot it should excite at a relatively low rpm compared to the one-wire setups.
17 years 1 month ago #10315
by ol Grump
Thanks folks. .the ideas put forth were pretty much what I'd thought. Guess it's time to recheck the wiring with a VOM to see if I've got a broken wire somewhere.
Paul
Thank you received: 663
17 years 1 month ago #10445
Sometimes alternators have slinger fans that work best when the fan "throws" the air outwards. Otherwise, it doesn't matter.
Neil.
17 years 1 month ago #10463
by ol Grump
I'm about ready to start pulling out what hair I have left on this one:mad: . .or maybe set an injector up to the pump and hit it with a torch and see how much hair and beard I have left afterwards:eek: per OM's suggestion.
What's happening is this: it's a direct drive conversion with an adapter that fits where the generator was. Wiring is direct from the large terminal to the battery with the red jumper wired to the terminal, the white wire through a switch and then to battery. Per ccjersey's question, yup, the back of the alternator does magnetize. All wires have been checked and rechecked, switch replaced several times and continuity checked. Everything checks out but yet, no movement of the ammeter and it's been replaced twice now too.
I finally broke down and ordered a laser tachometer as I'm not sure I'm getting enough revs at high idle. By marking the front pulley and turning the fan, it looks like the alternator is overdriven by around 1 to 1.125 or so. So at around 1000 engine RPM, the alternator should be turning around 1125 RPM.
At this point, I'm almost ready to get the original generator overhauled and try a 12 volt regulator. .almost!
Any suggestions? Sacrificing a tender young lady is out of the question. .there are no schools in this town however I HAVE been wondering if Matilda the Hun would work in this case. . . .
Thank you received: 820
17 years 1 month ago #10466
Some of them one wire alternators don't kick in until about 1200 rpm or more.
The low rpm cut in is about 850 rpm if you specify as such.
I realize you are not dealing with a one wire unit here but from what research I have done (now cold again) there are quite a variety of regulators with various capacities and cut in speeds including an all manual (switched control) version. Are you dealing with a commercial supplied unit or experimenting. Save the hair for another crisis. LOL
17 years 1 month ago #10467
by AJ.
Are you saying that the cable from the + terminal on the alternator is going directly to the battery, then the ammeter will not show a charge because there is nothing passing through it,look at the pictures below,its for a one wire alternator but it will give you an idea how things should be hooked up.
AJ
17 years 1 month ago #10469
Here's a couple more wiring diagrams. Same ones I sent "director" (congratulations) "7U puller" that he used to straighten out the D6 wiring mess.
17 years 1 month ago #10470
by Rep0144
If you are magnetizing the back of the alternator then you are producing power some of the alternator conversions on the old IH tractors they just put voltage meters on them that way did't have to fight amp meter. If this is an internal regulated alternator you need to make sure that the sencing voltage wire (not the batery wire that hooks to the back of the alternator) the sencing wire has to either have a switch or a diode in line or it will back feed and run battery dead. I have put alternators on some H's and B farmalls and they don't turn very fast.
Russell
Alternator problem
