rebuild kit for hydraulic pump D47U
mikedell
Send a private message to mikedell
Does anyone know of a rebuild kit for the hydraulic pump on a D47U?
It seems like the hydraulics are responding slower and slower, I put new cylinders on it the other day due to the originals leaking at the seals, so I grabbed a pair of new ones from farm and fleet, Ive looked for a filter but I cant seem to find one at all which seems quite odd, so Im assuming its pump rebuild time.
Thanks, Mike
Mon, May 26, 2014 8:02 AM
STEPHEN
If you have the Cat 44 pump, the filter is under a cover at the bottom of the unit, on the left side? I think
Mon, May 26, 2014 8:20 AM
mikedell
Reply to STEPHEN:
Ahh, Thanks Stephen, that I didn't know. Maybe the pump is okay after all. Will get the cover off and see if replacing the filter helps. Thanks again!
Mike
Mon, May 26, 2014 8:30 AM
jaker65
Send a private message to jaker65
Reply to mikedell:
Mike
if i am right, i have looked all over for the filter for my hydraulic pump on my crawler loader. the only place i could find it was at my local cat store. i tried napa and a few other places but came up with nothing. if you do get a new one, brace yourself for the price. last i checked they wanted 90 dollars for it.
Sat, May 31, 2014 7:34 PM
sr4440
Send a private message to sr4440
Reply to jaker65:
The earlier 44 pumps used the same filter as one of the fuel filters.
The later ones used a cartridge that is quite expensive.
No Idea when they changed
Sat, May 31, 2014 9:02 PM
STEPHEN
Reply to sr4440:
I think Baldwin made that filter as well, are they still in biz?
Sun, Jun 1, 2014 6:00 AM
