Hi Paul , Paul Moore is Pretty Handy in Toowoomba [0402071589 ] What are You Chasing ? If You are coming to Brisbane Give Me a Call ,only 15 minutes of the Bruce Hwy at Nambour. LJ
was thinking about getting some hydraulic track adjusters for my old 3T dont think they came out with them but the ones from a 17 a might fit Im thinking also chasing a hydraulic nose cone for a D 7 E tillys have one thought there might be something cheaper around they want $5500.00 seems pretty pricey to me but beggers cant be choosers so to speak then thought I might wander and have a look at chapter 18 meeting a lot of stars have to alinge first though well see what happens will give Paul Moore a call in the morning thanks for the number Lance if I get down will try to get in touch seeya
Paul
Hi Paul,
Expressway Spares may be able to help. Before I retired I did up a D6 U pony starter pinion clutch and brake assem. and tuned up the pony engine.
Not sure if they, like Tilley's, were looking to get out of early machine parts.
Think they have a branch in Mackay.
Tilly's prices for old stuff are far too high for most people. You should try David Tillyard in Tassie as he is often way cheaper than the rest even when you factor in the highway robbery freight costs across Bass Straight!
As an example David charged me a couple of hundred dollars for an item Tilly's wanted several thousand with freight on top. I don't call Tilly's anymore😊
will give them all a call gave Paul a call today didnt get a chance for anyone else but will try in the morning
seeya
Paul
Might be worth while trying Iron Farmers near Westwood on the Capricorn Hwy west of Rockhampton and Best Tractor Parts Mackay. They both deal in Cat tractor parts.
