Electric motor and reduction box needed.
Showing 1 to 9 of 9 results
John from Fresno
I stumbled across this injection test setup and need an electric motor and gear reduction box. The pump needs to be turned at 125 rpm.
See pictures.
Thanks,
John
Fri, Mar 14, 2014 10:17 AM
Looked like this originally.
Fri, Mar 14, 2014 11:51 AM
John from Fresno
Thanks Old Magnet,
I was hoping someone had a machine that had the electric motor and no injection stuff, so I could make a complete one from both. I also got a bunch of adapters for various injectors including one to test the capsule type.
John
Fri, Mar 14, 2014 10:36 PM
Bruce P
Reply to John from Fresno:
Thanks Old Magnet,
John
John, That is super cool. Good luck on your search.
Bruce P
Fri, Mar 14, 2014 10:49 PM
Reply to Bruce P:
Bruce P
The "Instructions for Caterpillar Diesel Fuel Injection Test Apparatus"
Form #11238-3 has all the info on the test end, but nothing on the motor other than gear head type.
I believe Bill Walter on here has the test unit and may be able to help with the motor identification.
Fri, Mar 14, 2014 11:22 PM
gary ca
John,
I have a 3 phase, 240 volt, 1 hp motor with gear reduction that probably turns close to that rpm. You need to make a Visalia trip. I will take a pic tomorrow. G
Sat, Mar 15, 2014 9:27 AM
STEPHEN
Reply to gary ca:
John,
I think they used a bodine gearmotor, the lovely black enameled units.
Sat, Mar 15, 2014 10:05 AM
gary ca
Reply to STEPHEN:
Here is the motor I have. I test ran this several months ago and if my senior memory serves me well, it was around 140 rpm at the first gear reduction. G
Sun, Mar 16, 2014 6:18 AM
John from Fresno
Reply to gary ca:
Gary,
I am not sure that motor is big enough. How many HP is that? I see it is sitting in my bay in my new shop. 😊
John
Sun, Mar 16, 2014 9:05 AM
gary ca
Gary,
John
I will double check today but I think it is one hp.
Sun, Mar 16, 2014 9:02 PM
| Hartley - South Australia
