Need Help Identifying Dozer
Showing 1 to 10 of 11 results
BrandonCrose
Send a private message to BrandonCrose
I have a Cat D7 - I have found a number on the left side of the engine not sure if this is a serial number but it reads #17A18869 Is this the serial number for engine or dozer? And also what does this # identify my machine as?
Tue, Feb 25, 2014 6:04 AM
oldparker
Send a private message to oldparker
That serial number identifies your machine as a Caterpillar D7D manufactured in Peoria, IL in 1961. The number is for the whole machine. John
Tue, Feb 25, 2014 6:58 AM
BrandonCrose
Reply to oldparker:
Thanks for the info!
Tue, Feb 25, 2014 7:08 AM
The engine serial number should be the same as the one on the left rear of the steering clutch housing. Machines of that time had 2 tags with matching numbers. If different numbers, the engine was replaced.
Later models (after early '70's??) had a separate serial number for the engine, but tractor serial number was still tagged on left rear of tractor (and stamped under tag...... if it's missing scrape paint off between the two rivet holes to see number).
Tue, Feb 25, 2014 9:04 AM
rustyfender
Send a private message to rustyfender
I can not find the serial number of my dozer. Where on engine is it located? It has a winch on the back and I can not see back there, but I am pretty sure the plate is missing
Tue, Jun 13, 2017 3:59 AM
seyser
Reply to rustyfender:
It should be on the left side of the engine near the pony motor engagement levers.
Tue, Jun 13, 2017 7:05 AM
Walt D7-3T
Send a private message to Walt D7-3T
Reply to seyser:
Here you go.
[attachment=42875]SN-Location - D7.jpg[/attachment]
Tue, Jun 13, 2017 9:37 AM
rustyfender
Reply to Walt D7-3T:
Here you go.
Thanks. Those are the locations Iam looking for
Thu, Jun 15, 2017 1:31 AM
trtmkowalchuk
Send a private message to trtmkowalchuk
Hi, I just acquired a D7 cat. The problem is I have no idea of the year or model. Could someone please help me decipher this number.
D73T20651
Thanks in advance.
Fri, Mar 16, 2018 8:06 AM
Claney
Send a private message to Claney
Reply to trtmkowalchuk:
D73T20651
Thanks in advance.
My book shows it to be a 1952 year model
C U Claney
Fri, Mar 16, 2018 8:26 AM
Some later caterpillar machines are divided into obvious series like the D7E 47 and 48A's where the E series is stamped on the serial number plate. The earlier series like the 3T/(4T and 5T military contract machines) did not list the series on the tag but I think they would have been the C series with the 17A being the D series.
On the older machines the main designation is the serial number prefix and size, so D7 3T or D6 9U.
Fri, Mar 16, 2018 10:04 PM
Price Tractor Pull
Price Tractor Pull
