I hope this photo helps. If it comes out too small to read send me a private message with your email and I will send a larger copy. The instructions for the brake band adjustment is simple, tighten until just snug(do not over tighten) then loosen one turn. Let me know if you need more info.![]()
Hi Kevin,
wondered where you had been 😊
Here is a TS guide for these systems from D6C to D9's of the day.
Hope this helps.
Eddie B.![]()
G'day. Thanks seiscat and edb for the info, it will help me out. Eddie, I did a heap of work on this tractor about 12-13 years ago including the engine and one F/D. She has 28000hrs on the clock but only 1000hrs since I did work on it. Now it is loosing trans oil and sometimes getting hot as well as other minor issues, pulled the belly guard off it today so I can clean it off properly and she's wet all around the valving at the bottom of the torque converter. I will keep you informed and will no doubt need to share some knowledge.
Kevin
