I was hesitant to repeat that since I haven't actually got a D311 to check the size of the plug. Only thing that makes me wonder if that is correct is I have a wrench I made that has a 15/16" head on it. Been so long since I made it, I can't remember what it fit or if it was simply a mistake. I did have a 212 grader here a few years ago and have a couple of D3400 engines out back that I could have made that for..........just can't remember.
I used the SEARCH function to find a 2011 Thread with DEAS reply in which he stated the same dimensions.
I feel pretty confidant that the HEX is the same size.
CcJersey,
That home made 15/16" wrench should fit the a drain plug on the grader, I can't remember exactly which one. I was in the process of changing engine and transmission oils at the time so it was somewhere in that area. .flywheel housing drain plug maybe?
I've built a number of various special tools for working on these old critters and paint 'em Cat yellow. One drawer in my tool box has been set aside specially for 'em.
