30 kw Cat generator
30 kw Cat generator
Showing 1 to 10 of 15 results
Dick Alcock
Send a private message to Dick Alcock
I just found this site and this is my first post.
I have a question regarding a older Cat gen set. It is located on the west coast of Cook Inlet, Ak. in a old cannery Called Snug Harbor which is located on Chisik Island. This place is a virtual museum and is filled with 4 steam engines, 11 generators, and a neat old Bolinder crude oil engine. My brother -in-law and I have been going up to Snug for the bast 5 years helping his daughter and her husband convert the cannery into a B & B or eco- tourist spot.
There is a 30 kw Cat Generator which looks complete still wired up to the cannery which we would like to use as a stand by generator. Last summer we tried to start it with no luck. There was diesel fuel at each injector and we gave it a couple of shots of either but could not get a pop out of the old girl. It has been sitting for probably the better part of 50 years in a dry generator building. We will be going up again this summer and would try again if I had some pointers on what to look for. I am not sure that we had the fuel shut off lever in the right place. we were just guessing on the correct position. I looked all over the office and could not find any operators manual or parts list. The former winter caretaker said it was always hard to start and was a rather dirty old leakier .
The diesel has the following id info: D311H 30TH 377 P.N. 7L14
Anyone interested can see the pictures of the cannery by looking up------Snug Harbor Chisik Island it is one spectacular place
Any help will sure be appreciated by one and all
Cheers
Dick Alcock
Mon, Dec 23, 2013 8:39 AM
Thank you received: 19
That would be an "H" series D311 s/n 51Bxxxx with generator s/n 30TH377 with 7L14 3-phase generator rated at 230-460V 60 hertz @ 1800 rpm.
Original choice of direct electric start or side mounted (buzz bomb) gasoline starting engine or compressed air starting.
Fuel shut off is valve cock. Should be a line or mark on top of the stem to indicate off/on or on would be with the stem square corners in line with fuel flow.
Sorry I don't have operators manual, just Parts Books.
Mon, Dec 23, 2013 9:33 AM
Steve A
I have a D311 gen set, oddly they made 2 different d311, the earlier 311 started at a 20 KW unit that ran at 1200 rpm, then 30 KW at 1800 rpm these units had the injector pump on the left looking from the gen end and a totally different unit that had the injector pump on the right that I know little about.
Does yours look like this ?
Mon, Dec 23, 2013 9:42 AM
Reply to Steve A:
Hi Richard,
your engine should have a Safety Shutoff System fitted and we will likely need some pictures so we can determine which type is fitted. Then we can advise you as to the re-set proceedure so you can overcome the rack shutoff to enable the engine to be started.
Usually requires setting a lever or plunger to allow the rack to be operated. From memory the shutoff usually dumps oil pressure to stop the engine, so it needs resetting.
Mon, Dec 23, 2013 9:50 AM
Dick Alcock
Reply to edb:
Hi Richard,
[quote="edb"]Hi Richard,
Eddie B.[/quote]
Many thanks for the super quick reply. Now for my first attempt to post pictures. not having any luck figuring out to up load pictures. I re-sized them to about 150kb not sure what or how your up load system works
Mon, Dec 23, 2013 10:57 AM
Reply to Dick Alcock:
Eddie B.[/quote]
Hi again,
I think the BB is having issues at present as several of us have had trouble posting pictures and links.
Mon, Dec 23, 2013 11:06 AM
Reply to edb:
Hi again,
There was a thread about a CAT GENSET up in Minnesota last year which had lots of photo's and discussion on the engine safety shutdown system.
I will try later today to link it if work isn't too busy........
Mon, Dec 23, 2013 7:25 PM
Dick Alcock
Reply to Steve A:
[quote="Steve A"]I have a D311 gen set, oddly they made 2 different d311, the earlier 311 started at a 20 KW unit that ran at 1200 rpm, then 30 KW at 1800 rpm these units had the injector pump on the left looking from the gen end and a totally different unit that had the injector pump on the right that I know little about.
Does yours look like this ?[/quote]
No it does not look like yours. The one at Snug Harbor does not have the exciter and the diesel looks different too. I am still trying to post pictures
Many thanks for you help and interest
Dick
Wed, Dec 25, 2013 3:02 AM
Dick Alcock
Dick
Any information regarding the safety shutoff system would sure be appreciated.
[attachment=20969]P6300081a.JPG[/attachment][attachment=20968]P6300080a.JPG[/attachment][attachment=20967]P6300079a.JPG[/attachment]
Wed, Dec 25, 2013 8:01 AM
It was a D4400 genset, I can't seem to post though?
OK, now its working!
Here is the link,
http://www.acmoc.org/bb/showthread.php?17646-D4400-Genset-louis-Allis-head
Wed, Dec 25, 2013 7:48 PM
Reply to drujinin:
Here is the link,
Reset is that plunger/button you see off to the left of the governor control.
Thu, Dec 26, 2013 12:01 AM
Price Tractor Pull
Price Tractor Pull
