oiler cups
oiler cups
Showing 1 to 6 of 6 results
blakeystew
Send a private message to blakeystew
On my 1930 fifteen i have 3 oiler cups on top of the transmition. There is one on the front that oils the main shaft (just in front of the slewing clutch leavers) And 2 on the back of the transmision that oil the slewing clutch bearings. What i want to know is what is the original cover that went on the top. I have spring loaded covers on and 2 are broken. Does anyone know the thread size of these as i have found spring loaded ones for sale. I have seen a pic of one that has a big thingy on there.
Thanks stew
Sun, Dec 15, 2013 11:09 PM
Jason 10/D4
Stew I think they are 1/8 inch npt its been a while since ive ordered any hopefully someone will chime in if im wrong. Mc master Carr has them. Jason
Mon, Dec 16, 2013 1:11 AM
blakeystew
Reply to Jason 10/D4:
Is this them??
http://www.thenippleshop.co.uk/acatalog/c17...jpg
Mon, Dec 16, 2013 1:49 AM
Jason 10/D4
Reply to blakeystew:
Is this them??
That's close but the cup could be a little bigger that will work for the two over the steering clutch but on my 15 the one for the throw out bearing is a little bigger than that. Ill see if I can get a pic. Jason
http://images1.mcmaster.com/Contents/gfx/large/1230kc1l.png?ver=12838775
That should be the one for the throw out bearing
Mon, Dec 16, 2013 3:22 AM
my old 7C Fifteen PB shows Gits #208 for the for the steer clutches, and #801 for the main clutch.
These numbers do not appear in Gits's current catalogue but, this link shows the current ones available under a different catalogue number.
http://www.gitsmfg.com/style-c-brazed-2/
These cups should have either a 1/8" NPT or 1/4" NPT thread.
Old NPR Caterpillar P/No I have for these cups is 1/8"=4B0354 and 1/4"=4B0576.
For rough estimation of pipe thread size you add 1/4" to the nominated thread size--twice the approximate wall thickness of pipe.
Thereby a 1/8" pipe thread will measure about 3/8" dia. and 1/4" will be about 1/2" dia.
Hope this helps.
Mon, Dec 16, 2013 6:20 AM
blakeystew
Reply to edb:
Hope this helps.
Thanks guys. I think mine are 3/8" they not as big as 1/2". So on the list of the gits the first 3 are the ones i need. Which do i need?? I'm really confused now.
In my parts book it shows 2 oiler cups part number no:208 for slewing clutch's and same part number no:208 for flywheel clutch bearing. Please help so i can get these ordered.
Thanks guys,stew
Tue, Dec 17, 2013 1:07 AM
josh
Thank you received: 6
Thanks guys,stew
The gits for the steering clutches and master clutch on my Fifteen's are both 1/8" NPT
Tue, Dec 17, 2013 4:28 AM
Price Tractor Pull
Price Tractor Pull
