Old Magnet D6-c 69j Model
Showing 1 to 6 of 6 results
7upuller
Hey Old Magnet,
It's been a little while. Mrs Huney is doing much better this last few weeks. I think the worst is behind us. It's been a long scary year.
I am familiar with the 10k model D6-c, but not the 69-j model. It's a 69-j 4235. What are the differences? Anything to watch out for?-glen
Fri, Nov 22, 2013 10:42 AM
Hi Glen,
Good to hear things are looking up.....a tough road for sure.
69J4235 would be a 1976 model. 3306T (44V) engine, powershift, Japanese built, 4,518 units produced with production ending in 1978.
A few numbers short of ROPS adaptability at 4395, ROPS became standard with next years model.
Not a whole lot different than the later 10K model as far as I know. The only thing that might be troublesome (and expensive) is the sleeve metering fuel system. Easily upset if water is involved.
Fri, Nov 22, 2013 1:25 PM
Wombat
Donor
Hi Glen,
D6C 69J series were/are a very common tractor in Australia, 140hp (however a serviceman told me the first few were 125hp). Very reliable, most in Australia were imported with ROPS mounts if not with ROPS. Check diagonal braces for cracks, welds and plates, possibly the weakest part of them, often welded, but not correctly ie out of alignment, wear rollers, idlers and tracks abnormally, they also suffer from the usual flat track D6 problems with the outrigger bush etc wear.
Fri, Nov 22, 2013 5:17 PM
ronm
Reply to Wombat:
Glen,
That is really good news-glad to hear she is doing better. I have been wondering...
Fri, Nov 22, 2013 10:10 PM
biggastractor
Reply to ronm:
Glen,
Glen,,
glad things are improving at home.
Good Luck
Biggastractor
Sat, Nov 23, 2013 1:44 AM
jfm3387
Send a private message to jfm3387
Reply to biggastractor:
Glen,,
Good Luck
Biggastractor
i have an old cat d4 i dont know the year but my left track will not pull however the left brake stops the dozer any ideas?
Sat, Nov 23, 2013 2:54 AM
Mervyn Pepper
Send a private message to Mervyn Pepper
Reply to jfm3387:
Hi Wombat; yeah a lot came to this side of the ditch too, but were by far the most common D6C here.
Yes early ones were non turbo at 125 hp. A lot of them came here too but were not well liked; many people said the old 76A/96A models were better; certainly sounded better 👍 Drove a 96A for awhile; old girl certainly ran sweet. They were turbocharged after 69J 1989. Early and mid ones all had compact fuel pumps but after 2882 had SMFS
Read in the AC post you had a 11-B then later a D6D; out of corosity how did they compare ??
cheers from kiwiland; Merv
Sat, Nov 23, 2013 2:57 PM
