LaPlant-Choate P9 Hyd Pump Gaskets
Showing 1 to 10 of 11 results
Cet119
Send a private message to Cet119
Just procured a D4 5T that has the 4-R Trailblazer setup on it. The hydraulic pump leaks between sections (actually pours out) under pressure, it does make good pressure, will lift the front of the machine up with ease and nearly stall the engine out. Prior owner said he had the pump worked over by a local shop but it started leaking right after he put it back on. I have read many of the posts on the mechanical shaft seal, but not found any info on the gaskets between sections. I can see some cork, maybe 1/32" thickness sticking out, is this the right material? I am more versed in more modern pumps and never seen cork used in the pressure sections... Best I can gather on the shaft seal is that you might be able to restore the sealing surface on the original but easier to find a modern seal that fits and stack a couple in there?
Charlie
Thu, Oct 10, 2013 6:41 AM
Kelly
Cet119
Charlie,
I don’t recall any cork gaskets in the pump for the 4R Trailblazer, tho they did requiring placing shellack on the face the gear case as these were ground and lapped joint which did not require a gasket. In some case they were a real thin paper gaskets use as gear house gasket on some units as I recall. I’d think the rotary seal assembly (parts number 26232) is the part that is causing the leak, if it is and the shaft is wore, you may have to use a ware sleeve on the shaft, or have it build up and turned down to the right size. Here is a couple of photos that may help. Let’s us know how things work out.
Kelly
[attachment=19977]LaPC_frontoilump.jpg[/attachment][attachment=19978]LP%Chrearpump%pressuresofreliefvalve.90008.jpg[/attachment]
Thu, Oct 10, 2013 10:04 AM
Reply to Kelly:
Cet119
Charlie,
Kelly
Thats an interesting comment you made that the pressure wants to stall the engine1
I would wonder what the relief valve is set for?
Your leaks maybe coming because of that.
Thu, Oct 10, 2013 7:42 PM
Cet119
Reply to drujinin:
Seems to run up to ~1000psi when letting the cylinders fully extend/retract and oil squirts from between the pump sections, probably from the shaft seal as well but it hard to see past the rainbow of shooting fluid. At full throttle definitely puts a load on the engine, probably not to the point stalling, but at idle I think it would.
Fri, Oct 11, 2013 4:04 AM
rmyram
never heard of a cork gasket between sections, can't imagine it sealing very much in a pump application especially at 1000PSI, normally they are a very thin piece of metal or paper. most newer style pumps use rubber seal that has the cupped side open to the discharge housing so that the pressurized oil can get behind the seal and expand it to make it seal better, a lot of the time they have brass plates that ride against the gears and the seal is behind the brass plates, it has a secondary function of reducing internal leakage past the sides of the gears. the paper and metal gaskets of old were very thin to also reduce internal leakage past the side of the gears. i have rebuiltgear pumps and used loctite 515 or equivalent metal flange sealant. it sets up and is about 0.001" thick after you bolt the halves together. as long as the gears still turn easily you should be good. if you have to use a wrench or pair of pliers to turn the shaft the end play is too tight and the pump will score the end housings or gear sides(faces) from lack of clearance. you can use metal shim stock to make your own gasket for between sections, it comes in brass or steel. and usually you can cut it with scissors. just make sure it isn't too thick as it will increase the end gap or float of the gears to the housing and you will have internal leakage past the gear faces.
Fri, Oct 11, 2013 4:58 AM
Reply to rmyram:
The 4-R Trailbuilder should have the pressure set at 450 psi. Even though 1000 psi is possible for other applications such as the Carrimor scrapers.
Fri, Oct 11, 2013 5:48 AM
Kelly
drujinin:
Comment about the pressure being set to high, could well be right. As a suggestion, one should make a pressure test with a hydraulic oil test gauge which has a pressure capacity of at least 1200 lbs. As, mentioned the maximum hydraulic relief value pressure is 450# for the dozer model in question. You might as a safety precaution back off the pressure relief valve some before testing the pressure and then raise it back up as needed to meet the 450# limit.
Kelly
Fri, Oct 11, 2013 8:21 AM
Cet119
Reply to Kelly:
drujinin:
Kelly
Thanks for all help, did have a gauge hooked up and cranked the pressure back to ~450 by which point most of the cork had pushed out of the flanges. Then took the pump apart, and reassembled with 515 instead of the previous owners cork. Only thing left is what to do with the shaft seal, all the parts look OK with the exception of the rubber, will try the local hydraulics shop and see what they have.
Sat, Oct 12, 2013 3:07 AM
STEPHEN
Reply to Cet119:
I just received in the mail a parts book for the C45 scraper dated 4-45 if I am reading it correctly. It has a diagram for the P9 pump with a notation "Pumps with round power and suction port bosses uses #19270 gaskets (2 ea) and the pumps with the octagon bosses do not use gaskets"
Fri, Oct 18, 2013 10:45 AM
Chuck C
Reply to STEPHEN:
Stephen, I have a C-45 scraper where did you find the parts book and could you make a copy for me
Chuck C
Sat, Oct 19, 2013 8:08 AM
STEPHEN
Reply to Chuck C:
Chuck C
[quote="Chuck C"]Stephen, I have a C-45 scraper where did you find the parts book and could you make a copy for me
Chuck C[/quote]
Chuck, I would be happy to make you a copy. Are you coming to Carthage to pick it up? or would you like it mailed sooner? Email your address. Oh, I found it on Ebay, now all I need to find is the scraper!
Sat, Oct 19, 2013 9:46 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
