Cat 3306TA
Cat 3306TA
Showing 1 to 10 of 20 results
jonno
Send a private message to jonno
Ive got a 1979 Leader truck (Mack copy built here in Australia) it runs a cat 3306ta engine.Since Ive had it Ive had the head off many times due to head gasket failure. Ive put on new head,spacer plate,bolts etc and it goes fine for about six months and then leaks at no5 cylinder. Im thinking now that the liners are not protruding past the spacer plate far enough to put enough clamping force on the head gasket. Does any one know the correct distance the liner should protrude.Im thinking of getting the spacer plate ground.
Wed, Sep 4, 2013 1:25 PM
L364
Send a private message to L364
Hello Jonno
Interesting have rebuilt a few 3306s etc,a few were fitted to trucks.
One I remember was fitted to a LEADER OVERLANDER and the owner had
renewed the head gasket several times. We were involved to see if there
was a unseen problem. With liner protrusion being considered, we removed
the pistons and liners and on close inspection we found the alignment was
out between the top and bottom liner bores. The owner continued the repair
himself with our recommendation to remove the engine and get the cylinder
block remachined to correct this mis-alignment problem. ???
This was over 20 years ago but I think it was either No 4 or No 5 bore.
Best regards
Gary
Wed, Sep 4, 2013 3:33 PM
catsilver
Reply to L364:
Hello Jonno
Best regards
Gary
The protusion of the liners should be around .004" with no more than .001" variation around the liner and between adjacent liners, (someone may have figures from a spec sheet, not my memory) check the top of the block where the liner sits, you will probably find it is eroded away and the liner is 'low' . The correct long term fix is to machine the block out and fit stainless steel inserts to carry the liners. Cat dealers have the tooling to do this work 'in frame' and its worthwhile paying their labour rates to get the job done properly for a long term fix.
This problem is the whole reason that the 'spacer plate' block was designed and first showed up on the D342 and D330/333 back in the 1960's.
Wed, Sep 4, 2013 3:47 PM
jonno
Reply to catsilver:
Thanks for the replys. I was hoping to avoid pulling the whole engine out but it seems that might be the way to go. Ill pull the head again and do some serious measuring before I go down that track Thanks Jon
Thu, Sep 5, 2013 6:02 AM
Thank you received: 23
Reply to jonno:
Hi Catsilver, for my education, how does the spacer plate work - is it designed to "soak" up variations between liner protrusions? Does it basically sit (and seal) between the liner and the head?
Thu, Sep 5, 2013 8:08 AM
jonno
Hi Neil I think catsilver may have got it wrong in his reply. From what I can see on my engine ( and I had plenty of looks!) the liners protrude from the block about 10mm (7/16in) and are seated at the bottom of the block.The spacer plate takes up the distance from the block to the height of the liners then the head gasket sits on top of it with the gasket sealing on a lip around the liners. Small rubber coated tubes fit in the spacer plate for the water galleries etc.Im not sure why cat would change the motor this way but it would be one way of increasing the capacity of the motor or lowering the compression.For what ever reason in my opinion its a pain in the neck.
Thu, Sep 5, 2013 4:37 PM
""""""From what I can see on my engine ( and I had plenty of looks!) the liners protrude from the block about 10mm (7/16in) and are seated at the bottom of the block."""""""
Not possible..........The liner has to seat in the block at the top so the bottom can "float" as it warms and cools. The o-rings at the bottom seal this movement.
Never seen a spacer plate, but it stands to reason the spacer plate puts a replaceable surface between the head gasket and the deck, protecting it from erosion. I am surprised the liners don't seat in the spacer plate. That would seem to be the best plan. That way if you replaced the spacer plate, you would get new seats without machine work and having to use shims etc to get the protrusion right.
Thu, Sep 5, 2013 6:31 PM
L364
Reply to jonno:
Hello Jonno
The spacer plate design does not change any of the engine operating parameters, compression etc.
It does add extra strength in the high load area of the engine. and removes the need to counter bore
the block which created stresses which can lead to cracking in the counter bore radius resulting in
dropping liners and coolant leaks etc.
Best Regards
Gary
Thu, Sep 5, 2013 6:50 PM
Reply to L364:
Hello Jonno
Best Regards
Gary
Hi Gary, if I'm interpreting what you wrote correctly, do the liners in a spacer plate engine sit right on top of the block deck (as opposed to in a counter-bore) and thus the space plate "makes up" the height difference for the head to sit on?
CCjersey, that would make sense to have the spacer plate "counter-bored" as you say then the only maintenance would be to plane the block and the head, and then throw in a new spacer plate, which, if was available in different thickness (e.g. std, 20 thou, 40 thou) could return your planed block/head to standard.
Thu, Sep 5, 2013 7:32 PM
catsilver
The spacer plate does away with the need for a block counterbore to fit the liners in, the block is then flat and easier to manufacture accurately, the liner flanges sit on top of the block. They are not supported at the bottom. I'm not always right and most is from memory but O M puts me right on specs, I was with a Cat dealership for over 45 years. and still enjoy solving engine problems.
Fri, Sep 6, 2013 4:30 AM
plowboy1982
Send a private message to plowboy1982
Reply to catsilver:
Let me look by chance I may have a shop manual for that engine and if so would be glad to just about give it to you seems like you need it way more than I do
R2 6J
Fri, Sep 6, 2013 5:01 AM
