fuel and oil filters D2 D4 and D6 pleas help
nielske
Send a private message to nielske
I am making a list for the D2 D4 and D6 witch filters they need included the numbers.
because there are so manny questions about it on the forum and now you have all the info on 1 spot.
so pleas take a look and add the missing info and correct my if i am wrong!
By pass change over kit to Full flow
Cat: 9F6430
[b]By pass filter
D4 7U1-7U12904
D4 6U-1 to 6U9063
D4 7J1-up
D4 2T1-up
D4 5T1-up
[/b]
Oil filter for by pass flow system Inner element (Disposable): 4A332(4A0332).
Alternate Numbers: Cat 6B0907,6F8358,8B5755,1S9150.
Outer Element (Washable):6B1851.
1 Fuel filter assembly: 7B8264
Or
4 Fuel filter: 2A5886
2 Fuel filter Gasket: 7B7635
[b]Full flow filter
D4 7U12905-up
D4 6U9064-up
[/b]
1 Full flow filter, Cat number 9F6700 or 1R0659.
Or
[b]By pass filter
D2 3J1-Up
D2 5J1-UP
D2 4U1-4U6373
D2 5U1-5U13237[/b]
1 Fuel filter assembly: 7B8262
or
3 fuel filters: 2A5886
1 fuel filter gasket: 7B8037
1 fuel filter gasket: 5B1581
[b]Full flow filter
D2 4U6374-Up
D2 5U13238-Up
[/b]
or
[b]D6 4R-?
D6 5R-?
D6 8U-?
D6 9U-? [/b]
2 Full flow filter, Cat number 9F6700 or 1R0659.
by pass??
fuel ??
Mon, Aug 26, 2013 1:04 AM
