D6 32a ???
D6 32a ???
Showing 1 to 10 of 14 results
Palmer
Send a private message to Palmer
There is a D6 32A for sale in Australia and I would like to know more about this model. I can't seem to find any information about the 32A. Is this a credible model No??
Thanks.
Wed, Jul 31, 2013 5:54 AM
ianoz
I think it will be an Australian Built one .
Wed, Jul 31, 2013 6:08 AM
Hi Palmer,
32A is the equivalent of a 9U D6.
This D6 came from the States as a skid pack out to the ends of the final drive dead axle caps.
To qualify for an Australian Serial Number and, I believe import benefits, Cat of Australia built all the track frames and related undercarriage--yes, rollers, tracks, etc.
CofA also built the blades, etc. for these as well.
Wed, Jul 31, 2013 6:16 AM
Inter674
Reply to edb:
Hi Palmer,
I wonder if parts for these machines were also outsourced eg., to Steelweld who built many parts for the D4 30As?
But I think Cat had p'd them off by 1957-58.
Wed, Jul 31, 2013 4:23 PM
Palmer
Reply to Inter674:
Thanks for the info.
Edb, Would this mean that the 32a is a partial Australian built D6a or D6b?
I had thought that the D6A (8U-9U) was fully imported into this country or have I got this all wrong. Thanks for your advice.
Cheers
Geoff.
Thu, Aug 1, 2013 4:05 AM
84WD10
Send a private message to 84WD10
Reply to Inter674:
HI D6 32
I noted with interest your query regarding the Australian built D6 32A series tractors, they were built by Caterpillar in Australia - for two production years only - 1958 & 1959. and they built only 177 of these tractors. Hope that this puts your queries to rest.
Regards
Alan T. Lewis
Christchurch
NEW ZEALAND
Thu, Aug 1, 2013 4:09 AM
Reply to 84WD10:
HI D6 32
Regards
Alan T. Lewis
Christchurch
NEW ZEALAND
Hi again,
any D6 with 8U-9U S/No would be imported intact fully built.
The 31A-32A is part OZ built as described above, and if I recall correctly was only known as a D6--no A or B etc. I believe the B did not come in until after the USA 37A-44A, Aust. 56A-57A, were built in 1959.
Thu, Aug 1, 2013 9:38 AM
D6 Pete
Reply to edb:
Hi again,
These aussie track-frame,aussie assembled tractors came out late in the 9U, 8U series time,, and had the late 318 with a little more HP ,easely can be identified by the twin fan belts and larger CATERPILLAR print on side of block . Ive known of a fair few of them here in Qld. Always wanted one ,for that later 318.. They also a had a sharper bark, the pump was altered slitely ," spring& shimms", ive been told!...,, And if blades were fitted and they did hard work,, the aussie built diagonal-brace on trackfame would be bent and or plated with weld!!,,, ive never seen a US built Cat one welded -plated!!., the aussie diagonal brace had only a small hole in it (where the dirt sits} the US 9U has that big triangle hole for the dirt to fall thru. !.another way to see if its a 32A or 9U !,,,.. pete
Thu, Aug 1, 2013 11:51 AM
D6 Pete
Reply to D6 Pete:
Where is the D6 for sale at !? ,, in Aussie . Thanks ....pete
Sat, Aug 3, 2013 5:34 AM
rusted
Send a private message to rusted
Reply to D6 Pete:
I'd suspect it's this one.
http://www.gumtree.com.au/s-ad/mansfield/heavy-farming-agriculture-equipment/caterpillar-d6-32a-bull-dozer/1024710454
Sat, Aug 3, 2013 6:56 AM
Palmer
Now that you lads have had a look at the machine, what do you all think of it?? Let me know what your thoughts are.
Is the price excessive for this type of machine in OZ?
Would parts still be available for undercarriage etc?
Sun, Aug 4, 2013 6:59 AM
