D7-17A and pull scraper
Showing 1 to 9 of 9 results
panner60
Send a private message to panner60
I was thinking of moving some dirt around the farm, and I was wondering what size of scraper would be matched to a D7-17A?
Mon, Jul 29, 2013 7:20 PM
Modern hydraulic scrapers or old CAT cable control models?
Mon, Jul 29, 2013 8:01 PM
panner60
I would like the hydraulic model as my dozer doesn't have the CCU. But what cu. yd. would the D7 be able to manage?
Mon, Jul 29, 2013 8:14 PM
Old 3T lover
Reply to panner60:
I used 3T and 17A D-7's to pull a LeT. LS scraper that was 8 yards struck and 10-11 heaped. That was a good match and enough for them.
Mon, Jul 29, 2013 8:36 PM
panner60
Reply to Old 3T lover:
Thank you for the info. Our County here has 5.5, 8 and 13 cu. yd. scrapers that they rent out fairly cheap and I didn't want to get something smaller than what I would be able to use.
Mon, Jul 29, 2013 8:41 PM
[attachment=18719]Dam pictures 2012 002.jpg[/attachment]There are so many variables of soil type, scraper design, haul distance etc, it would be hard to give you a concrete answer, but I would go with the 13 yard for sure. A 17A is going to have more traction/draft than most any rubber tired tractor less than 400 hp, so I think you could handle that easily. If you're going any distance, the extra payload is going to make a dramatic difference in how much dirt your get moved in a day.
When you're pulling a scraper, the width of the bit and how the bowl is made determines how hard it pulls and how effectively you can load it. If it has a "frost bit" in the center of the cutting edge, you can take cuts with that part only if the dirt is really hard or you don't have good traction. As an example of that, we have a small LaPlant-Choate 4 yard ejector pan which we pull with farm tractors. When the frost bit was long enough to use, we could pull it with a 4020 JD or do a really good job with a 5020, so 95 to 130 hp or so. It's old and the frost bit is worn so that it usually cuts with the whole 5 or so feet of bit at once and now it really works best with a 4955 MFWD about 225 hp.
Does your tractor have an auxillary hydraulic system or a CAT front mount hydraulic control? Just wondering if you have the number of valves and pressure capability you need.
Tue, Jul 30, 2013 1:27 AM
Thank you received: 20
In the cable versions, 13 cu. yd. is considered D8 size.
Tue, Jul 30, 2013 1:44 AM
panner60
My dozer has the Cat front mount hydraulics, but the previous owner had put two fittings on one of the C-frame lift cylinders, I was going to put some quick connectors there. But you were wondering if I would have enough pressure to operate the scraper?
Tue, Jul 30, 2013 2:47 AM
Reply to panner60:
The D7-17A would have a #46 hydraulic control. Pump rated a 100 gpm,
Maximum working pressure 1000 psi.
Tue, Jul 30, 2013 3:52 AM
17a Nebraska tractor test link
http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=2101&context=tractormuseumlit
Pertinent data
Weight as tested 30,460 pounds
Drawbar pull 1st gear ~26,000 pounds@ 1.5 mph
second gear ~ 18,000 pounds @ 2 mph
third gear ~ 12,000 pounds @ 3 mph
John Deere 9100 4WD articulated tractor
http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=3093&context=tractormuseumlit
Weight as tested 33,548 pounds (Tractor data has the weight at less than 29,000 pounds so more likely to find a tractor weighted for agricultural use that is less than the Nebraska test weight)
Drawbar pull 3mph ~ 23,217 pounds
4.4 mph 16,544 pounds
6.3 mph 11,670 pounds.
This is just to point out that the 17a is about a 120 pto horsepower tractor while the comparable modern era 4wd is 240 or so engine horsepower. As expected, at each level of draft, the speed is about twice the 17a. I've never run a big scraper with a tractor like that, but I doubt they last very long if you get them down in the creeper gears where their drawbar pull is greater than the 17a. I know a good CASE IH mechanic that worked on a lot of scraper tractors, I'll ask him tomorrow. I know he fixed a lot of broken tractors that were hooked to scrapers, so he should know what it took to break them.
I think the hydraulic pressure is likely to be the killer in this deal. Modern hydraulic designs are going to be using at least 1750 psi as a minimum design parameter (if not higher). You may find that you cannot lift the loaded scraper out of the cut or cannot dump it. The manufacturer or dealer for the scraper can supply the operating requirements.
Tue, Jul 30, 2013 8:58 AM
