3208 engine runs but not good
Showing 1 to 10 of 13 results
jaker65
Send a private message to jaker65
hey all,
once again i have another problem but not with my crawler loader this time. its the 3208 engine in my ford dump truck. i noticed sediment in the bottom of the fuel tank a while ago and thought nothing of it. i knew better though but i just needed to move the truck a few feet so i took a chance. well after it shut off and wouldnt start back up i took a closer look. turns out to be the red alge in my fuel tank. and there was a lot of it too. so i just got done cleaning out the fuel tank with a pretty good cleaner we use at work for cleaning blacktop off our milling machine. i took apart the fuel line and blew air through them away from the injector pump so i did not introduce any big chunks there. i also replaced the fuel filter and cleaned the lines to it.
i primed the fuel lines with the manual fuel pump on the engine and turned the engine over and it fired right up. had it running good at 2500 rpm for a couple min and then let the rpms drop back down to idle. it started to jump around on the rpms and then it just died. i reprimed the fuel lines again and tried to turn it over and nothing. i then cracked the injector nuts at the top of the valve pan covers and primed the lines again and after that the engine started right up. the rpms still jumped but if i held the throttle open a little it would run smooth. at this point im not sure what i could do to make it run a little better. i need some advice on this one. thanks for helping me.
Mon, Jul 15, 2013 1:44 AM
bob
Send a private message to bob
Check the fuel return line back to and into the tank(blow air into tank with cap off).
This line is a constant bleed line to take care of any air the pump picks up.
Later Bob
Mon, Jul 15, 2013 3:30 AM
jaker65
Reply to bob:
Later Bob
seems like a logical answer, i wasnt able to blow that line out, but i will tomorrow night. right now its blazing hot out there and i just started my laundry haha 😊 i did notice that the return line wasnt putting much back into the tank. just a few drops at a time. thanks for the advice!
Mon, Jul 15, 2013 4:17 AM
Reply to jaker65:
Hi jaker65,
I posted a possibility on this thread linked below a while back.
Hope this helps.
http://www.acmoc.org/bb/showthread.php?18284-Cat-225-fuel-trouble&highlight=sleeve+metering+injection+pump+air+bleed
Mon, Jul 15, 2013 7:52 AM
jaker65
Reply to edb:
Hi jaker65,
Hope this helps.
Hey Eddie
The post did help out some. I got the aair out of the fuel lines sand fired up almost sad soon as I turned the key. It ran fine, I opened up the bolt on top of the pump and got the air out there. But after running half throttle for 5 min I let it idle, then wafted a min the rpm's started to jump again. I made sure the fuel return line was clean and got a nice steady flow goin back into the tank. seems like it is running out of fuel or starving itself. When the rpm's start to jump, I go and prime the engine with it running and it smooths out. But only for a little bit. I took the main line off and blew it back out and made sure it was clean was well. So far what I have done seems to have made it run better I can say that. Thanks again for the help
Sun, Jul 21, 2013 12:11 AM
Reply to jaker65:
Hey Eddie
Hi jacker65,
good job there mate.
Seems like you may need to check for restriction in the fuel tank return line fitting and stand pipe at the tank itself as you still seem to have the problem to a lesser degree.
Next make sure there is no restriction to the fuel supply as, the fuel transfer pump is bolted onto the front of the injection pump so the entire inlet side fuel lines, screens and the fuel filter itself are under vacuum-low pressure- any leaks here will cause aerated fuel that will slowly build up again in the pump body.
Maybe put a clear section of fuel line at the pump inlet to observe for aeration.
Failing that the pump will need to be removed and the front bush checked for wear also to reseal the transfer pump section bolted to the front of the pump itself.
Sun, Jul 21, 2013 8:41 AM
L364
Send a private message to L364
Reply to edb:
Hi jacker65,
Hello jaker65
Yer as edb said the fuel supply upto the fuel injector pump is under low pressure (vacuum),
subject to line and filter restrictions.
The higher the restriction the greater the possiblilty on air entering the system resulting in
low power, unstable engine revolutions and hard starting.
As edb said I to had a clear plastic tube to test for air entery before the fuel pump.
Found on many occasions that fuel lines and fittings were loose or holed and at one
time CATERPILLAR were getting filters through another manufacture and the filter head
seal was under size and alowing air to enter.
Goodluck
Gary
Sun, Jul 21, 2013 1:10 PM
Gavin84w
Reply to L364:
Hello jaker65
Goodluck
Gary
I had a poor running Louisville once that had a 3208 in it and initially i got a drum and plumbed it straight into the fuel transfer pump. The engine then ran fine never missing a beat, so i then sorta knew where the issue wasn,t!!
At the rear of the RHS head there is a block where a couple of fuel lines are and turned out there was a small piece of what looked like rubber maybe from a hose or something like that and it was caught where the 90 degree elbow was at that block and while you could blow it with air and it sounded wide open when it had fuel being drawn through it it would jam and restrict the flow.
Sun, Jul 21, 2013 6:37 PM
jaker65
Reply to Gavin84w:
hey everyone,
well i am back with more results. i got the engine running pretty good now. yesterday i went through rechecked all the fittings and lines and the breather line on the fuel tank itself. everything was okay. i took the filter back off, dumped out some of the diesel fuel and filled it up full of injector cleaner. re primed the fuel system, and it started up. i threw a brick on the gas pedal and let it run at 1,000 rpm for a good hour. took the brick off and let it idle. so far so good, i let it idle for a good 30 to 40 min and it never sputtered once nor jump in rpm. i also did bleed the air from the injector pump once again. i must not have got all the air out the first time. i then hit the throttle and quickly released it, the rpm went back down to the normal 500 range and didnt jump at all. i went back out today, started the truck up, let it idle again with no problems, i hit the throttle and held it up for 5 min, came back down and didnt jump. so i let it idle again, then it did jump the rpm range so i held the throttle down for 3 min, and turned out okay. didnt jump anymore. so am i safe to assume that most of the problem is gone or might there still be some air in the system? also is the fuel filter suppose to be full of fuel when running or only half full? last time i took it off after running the engine, it was only about 3/4 full of fuel, but i did hear it suck air when i broke the seal and did hear some of it drain back down into the tank.
Wed, Jul 24, 2013 8:28 AM
Reply to jaker65:
hey everyone,
Hi Jake,
the fuel filter should be full of fuel.
By your description you may have a part blockage down stream from the filter as the only suction should be from the head of fuel from the filter location to tank fuel level.
Check the tank breather system as a blocked breather will cause big suction in tank similar to your description.
Can you get to see the pick up in the tank. Sometimes fluff or rag, grass etc can wash against the pick up and block/restrict it and then clear away if you back blow with air etc.
Some pickups can have a sock type strainer fitted and this could be part clogged with lint/crud.
Not the first time a stand pipe/pickup tube has part fractured from vibration and cause air leaks.
Can you remove the stand pipe and check its integrity at the upper end--could also be rust holes in this pipe.
Eddie B
Wed, Jul 24, 2013 10:21 AM
catsilver
Reply to edb:
Hi Jake,
Eddie B
As EDB says, you have a partial blockage in the suction line, you are getting plenty of fuel to run off load, but what happens when you put it under load? This is when fuel demand is greatest, check that you have plenty of flow in the return line and see what the pressure is under load to get a proper picture, i came across this problem on a 3208 in a harvester many years ago, OK until you put it under load when it started to splutter and fuel pressure dropped away, I found the first elbow in the top of the fuel tank plugged with grass.
Wed, Jul 24, 2013 2:59 PM
