Cleaning out used hydraulic lines?
Gregness
Hi guys,
I have the cross-over pipes for my D2 here, getting ready to clean them up and mount them on the cat. Not sure how long they sat in the wrecking yard in Boise, but there is probably dirt and bugs inside them. Any recommendations for cleaning them out? I was thinking:
Step 1: Hi-pressure water blast though them to take out lose crap.
Step 2: Run cleaning solvent through them for a while to remove more crap, chase out water.
Step 3: Run used (but pretty clean) hydaulic fluid through them to remove solvent.
Should I also fab up some sort of brush to pull through them? They area about 40 inches long.
All proven ideas welcome!
G
Tue, Jun 11, 2013 1:59 AM
Thank you received: 29
Start with air, some of the dirt comes out better dry than after it is wet.The rest of your ideas seem good to me.I have used a fair amount of used hydraulic hose and pipe over the years and never had problems that I thought were caused by dirt from used components.
Tue, Jun 11, 2013 2:50 AM
STEPHEN
Reply to Ray54:
braze a tube brush onto a 3/16 wire rope and pull through. there are a lot of things that could withstand an air blast, solvent cleaning, and even some water flushing:
1)remains of dirt dauber nest
2)surface rust
Tue, Jun 11, 2013 3:33 AM
Reply to STEPHEN:
2)surface rust
boiler brush--should reach across the length of the tube
Tue, Jun 11, 2013 5:18 AM
Gregness
Reply to dpendzic:
Thanks boys, looks like I am going shopping.
Tue, Jun 11, 2013 7:40 AM
Reply to Gregness:
Tube Brush? Guy at the Hardware store will give you a blank look.
Boiler Brush? The same Guy will send you to a Plumbing/Heating Supply store where you will pay through the nose because you don't have an account.
INSTEAD!
Go to your local Sporting Goods / Gun Shop and buy shotgun cleaning brushes! All you have to do is shove a wire down the tube, tie on the brush and pull it through. 👍
I definitely agree on flushing them.
Brush, Flush, Brush Flush. That way you get the big chunks out and then scrub loose the surface rust.
Tue, Jun 11, 2013 6:22 PM
Gregness
Reply to drujinin:
INSTEAD!
[quote="drujinin"]Tube Brush? Guy at the Hardware store will give you a blank look.
INSTEAD!
Brush, Flush, Brush Flush. That way you get the big chunks out and then scrub loose the surface rust.[/quote]
Hell, I got one of those right here! Never would have thought of that! Thanks!
G
Tue, Jun 11, 2013 10:03 PM
STEPHEN
Reply to Gregness:
INSTEAD!
G
Yes on the shotgun brush. I get tube brushes from the vendors at the local engine/tractor show. I use them quite a bit in my cordless drill when cleaning parts in the solvent tank.
Tue, Jun 11, 2013 10:16 PM
Reply to STEPHEN:
yep i have shotgun brushes too and also boiler brushes for when i clean the boiler each year
Wed, Jun 12, 2013 12:00 AM
