Part numbers identification
Showing 1 to 10 of 14 results
ob98
Send a private message to ob98
I have come upon a few boxes of NOS Caterpillar parts. There are part numbers on the boxes and on the parts with a name as what they are (impeller, shaft, lever etc) but, I can not find any place on the Internet to tell me what these parts actually fit. Am I at a dead end?
Tue, May 21, 2013 10:31 AM
Thank you received: 12
Post the part numbers here (ideally with a photo of the part) and the crew will identify them
Neil.
Tue, May 21, 2013 8:36 PM
ob98
Neil.
[quote="Neil"]Post the part numbers here (ideally with a photo of the part) and the crew will identify them
Neil.[/quote]
Thanks. I will do some of them later today. (I did post some photos of intake and exhaust valves in the for sale section). Thanks.
Tue, May 21, 2013 8:49 PM
ob98
Reply to ob98:
Neil.[/quote]
Here are a few to get started: Thanks!
[attachment=17866]2P1725.jpg[/attachment][attachment=17867]5p4784.jpg[/attachment][attachment=17868]5p6188.jpg[/attachment][attachment=17869]5S6297.jpg[/attachment][attachment=17870]9L503.jpg[/attachment][attachment=17871]9S8041.jpg[/attachment]
Tue, May 21, 2013 10:15 PM
d9gdon
Reply to ob98:
2P1725 shaft is water pump shaft for D8H SN27729-up
5H4784 lever is one of 4 levers used in D9 tractor and 583 pipelayer in arrangement 3L-1584 torque converters
5P6188 sleeve is not in SIS (some tractors and equipment are not in there)
5S6297 seal is a crankshaft seal for a D330C engine used in many applications NOTE: this item says in the system "with seal for worn flange". It doesn't give the part number of the sleeve. I would feel sure that's where the 5P6188 sleeve goes in the mix.
9L503 impeller is for a 1673 truck engine on a 9L-2279 water pump assembly
9S8041 impeller is an impeller used in many applications: D7F military tractor, 941 track loader, 930 wheel loader, 966 wheel loader, 627 scrapers, 815 compactor, 950 wheel loader, and I'm tired of typing...there's about 30 more applications with lots of different engines.
Wed, May 22, 2013 12:58 AM
ob98
Reply to d9gdon:
Thank you very much. That is a great start in ID'ing these items. I also have some valves listed in the for sale section that were labeled "318 valves", however, there are too many different ones for them all to be for a 318. I have listed the part numbers there also that are imbossed on the flat of the valve heads. I have quite a few more parts I will put up later. I have a box of parts that are labeled for a "D7 Turbo" too. Thanks again. keith
Wed, May 22, 2013 1:31 AM
ob98
Reply to ob98:
I have so much of this stuff I am afraid I will over use my welcome. But anyway, here are a few more:
1. 7M9908 Sleeve
2. 7M9922 Bearing
I took a photo of one of the following, (Items 3,4 and 5, they physically look the same)
3. 7S1059 CAT. G
4. 7S8722 CAT. A9
5. 7N5005 CAT. F1
[attachment=17956]cat part 3c.jpg[/attachment]
6. 3N0584 Made by Delco,
[attachment=17957]cat part 3a.jpg[/attachment]
7. 6L2673 impeller
8. Unknown Part number for this seal: 4 5/8" OD, about 3 1/2" ID.
[attachment=17958]cat part 3b.jpg[/attachment]
Thanks!
Fri, May 24, 2013 9:00 PM
d9gdon
Reply to ob98:
1. 7M9908 Sleeve
2. 7M9922 Bearing
3. 7S1059 CAT. G
4. 7S8722 CAT. A9
5. 7N5005 CAT. F1
7. 6L2673 impeller
Thanks!
7M9908 Sleeve-flinger; Used in turbo for lots of different engines, gas and diesel
7M992 Bearing; Ditto above
7S1059 Fuel nozzle(capsule type injector); D342, D343,D346,D349,D353,D379,D398
7S8722 Fuel nozzle ; D330C and 1673C truck engine
7N5005 Fuel nozzle ; D346, D348, D349
3N0584 Shut off solenoid ; Lots of applications
6L2673 Impeller; D320, D330, and D333 engines
Sat, May 25, 2013 1:02 AM
ob98
Reply to d9gdon:
Thanks again! Am I right thinking the impellers listed so far are for water pumps?
Here are more:
7B2174, seal. One is a Cat. part and the others say CHICAGO ALLIS, same p/n.
5S6622, Seal.
DR-1481, looks like a starter solenoid?
3S6638, nozzle.
2S3966, nozzle?
6N9373, Pump seal D7E, water pump?
3K1650 24V switch, Heat and start?
6H3491, Seal assy, rubber load spring?
6H3347, (6F160 nozzle)
4F4769, Seal assy, carbon in steel?
1H2831, Rod bearing, .030, D4 Start engine
AC Fuel pump and sediment bowl, Model B, 855228
300 5652274, switch
6B1124, ball bearing
1F1273, bushing
8S8821, seal
2A4725, ball bearing
3B3985, Race
Thanks. keith
Sat, May 25, 2013 2:01 AM
d9gdon
Reply to ob98:
Here are more:
5S6622, Seal.
3S6638, nozzle.
2S3966, nozzle?
300 5652274, switch
1F1273, bushing
8S8821, seal
3B3985, Race
Thanks. keith
Yes, all impellers(you listed) are for water pumps.
Wish I knew somebody with a 3K1650 switch, mine hangs.😉
Going outta town, I'll catch the others tomorrow.
Sat, May 25, 2013 5:54 AM
d9gdon
Reply to d9gdon:
7B2174 seal; lip type seal, 336 entries, numerous applications
5S6622 seal; lip type seal, 377 entries, numerous applications
DR-1481 is not a Cat part number, prolly a Delco Remy starter solenoid used in Cat applications
3S6638; fuel injection valve for 561 pipelayer, 951B track loader, D320 engine, and 977 track loader
2S3966; ring(water pump), 235 entries, numerous applications: D343,D346,D349,D379B,D398B,D399,G342,G353,G398,G399 not sure where you got nozzle from?
6N9373 No entry is SIS (I know the D7E is not in the system)
6H3491 seal(water pump bellows seal), 251 entries, same big engine applications D343,D346,D349,D379B,D398B,D399,G342,G353,G398,G399
6H3347 fuel injection nozzle; D8H and 583 pipelayer, and Marine Engines of the following sizes: D326,D337,D363,D375,D397
4F4769 water pump shaft seal; 158 entries, same big engine applications as 2S3966 above
1H2831 starting engine rod bearing; D315 Marine Engine
No matches on the next two items:
AC fuel pump
300 5652274 switch
6B1124 fan drive ball bearing; 932 entries, looks like it was used in fan drives in lots of different applications, even up to current engines
1F1273 No entry is SIS
8S8821 water pump shaft seal; 985 entries, used in lots of different applications in big engines but more modern than the others above like 3408, 3412, 3516, 3304, 3306, 3512
2A4725 bearing; used in governor on engines D326, D337, D342, D353, D375, D397
3b3985 race; 81 entries, race used in PTO's and direct drive transmissions in lots of different tractors
Remember that there may be other applications. If they're not in the system, I can't pull them up. A lot of the older stuff is not in the system.
I got your PM and I'll gladly pay that. I'll get my info to you. Thanks
Sun, May 26, 2013 5:40 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
