D7 3T hydraulic blade parts and service info?
jonstark
Send a private message to jonstark
I have a 1956 D7 3T with a hydraulic blade. I have the tractor service and parts info but nothing on the hydraulic system. Can anyone please direct me to a source?
jon
1981 D3B, 1955 D7 3T, 1954 Ford Jubilee, 2001 Kubota L3010
Wed, May 8, 2013 9:53 PM
Thank you received: 19
Hopefully you can find some serial numbers....Blade s/n should be on the RH rear near the top of the mold board. Most likely a #17C5001-up for the angle dozer or 17C1 to 17C5000 or 84C1-up for the straight blade.
Uses the #46 Hydraulic control, look for a s/n plate on the left hand side of the rear face of the Hydraulic Control tank assembly. Most likely a
2Wxxxx number. This will get you the parts breakdown.
As far as service and repair you will need the Servicemens Reference Book Form #12914 Hydraulic Controls and Equipment.
First place to go looking would be ebay.
PS, I show 3T production ending in 1955.
Wed, May 8, 2013 10:43 PM
jonstark
Found one for $18 right away. Didn't know what to look for until your advice. Thanks.
It IS a 1955. My mistake.
jon
Fri, May 10, 2013 8:25 AM
